Old 06-29-2018, 01:24 PM   #1
thevoice_692001
thevoice_692001's Avatar
Arrow HELP with this problem plz
I am looking for help getting my wife's dream truck I just got her running.
I just got my wife a 1969 C-10, 350, manual, truck. It sat without any gas in it for 9 months. We replaced the battery, put treatment and new gas in it. The truck will run if I keep spraying the starter fluid into the carb, but will not seem to run on just the new gas we put into it.
It was a dry tank and I added only 5 gallons. I have checked everything I know to check, but there is a manual choke cable in the dash and laying unattached on the fenderwell in the engine compartment.
Any advice would be greatly helpful
Joseph S Risenhoover
thevoice_692001 is offline   Reply With Quote
Old 06-29-2018, 01:41 PM   #2
Jeff's bowtie's
Re: HELP with this problem plz
Make sure the fuel pump is pumping gas.sometimes the diaphragm in the pump will dry out and pump gas into the crank case
Jeff's bowtie's is offline   Reply With Quote
Old 06-29-2018, 04:43 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Welcome! There could also be a clogged fuel filter, and there may be more than one to check / replace. If it has a Q-jet, there's a small filter at the inlet tube.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-29-2018, 04:55 PM   #4
franken
Is gas shooting from the accelerator pump squirters?
Is gas being pumped to the carb?
Today's gas has methanol in it, which attracts moisture (water) and rots fuel systems. Chances are you need to clean and/or rebuild the carb, and clean out the fuel system. That's carb, fuel lines and gas tank.
