Old 12-11-2016, 01:01 AM   #76
whytry85
whytry85's Avatar
Re: Project: 3rd times a charm: 83 c10!
Been awhile since I updated. I haven't really worked on it much the past few months. Just mostly gathering parts.
Did decide on a ls swap (lq4) and ordered he vintage air, scotts under dash pedal assembly and an ididit column so I can start on the engine bay and firewall. Also, got the drivers fender about 60% done. Needs some more planishing and fine tuning but it's getting there.
whytry85 is offline   Reply With Quote
Old 02-12-2017, 02:17 PM   #77
3drburb
Your fender looks very nice. Any more updates.
3drburb is offline   Reply With Quote
Old 04-04-2017, 12:31 AM   #78
whytry85
whytry85's Avatar
Thanks bud! Haven't really messed with it in the last few months. Got a room full of parts waiting to be installed but have been working on a lot of side projects at the shop trying to get a little more cash. About to be finishing up a 57 3100 here soon and will be back on the c10!
Build thread:http://www.67-72chevytrucks.com/vboa...d.php?t=663953
Instagram: Whytry85
Old 04-06-2017, 03:37 PM   #79
stepside83
stepside83's Avatar
awesome build, great work for sure, cant wait to see more of it
stepside83 is offline   Reply With Quote
Old 04-06-2017, 09:31 PM   #80
3drburb
We could enjoy the progress pictures of the 57 Chevy also. Lol
Old 04-08-2017, 10:41 PM   #81
whytry85
whytry85's Avatar
Thanks man! I'm ready to get back on it!
It's nothing to write home about.. just some patch panels. I'll post pics though to keep the thread active lol
Instagram: Whytry85
Old 04-08-2017, 10:51 PM   #82
whytry85
whytry85's Avatar
Some the 57 3100 repairs I'm doing.
Cut out rust
Fitting the new replacement panel
Fully tig welded and planished out. Still needs some work but it's about 90%.
Instagram: Whytry85
Old 04-08-2017, 10:55 PM   #83
whytry85
whytry85's Avatar
Oh I did get pretty big stash of parts of a month or so ago. Now just need more hours in the day.
Instagram: Whytry85
Old 04-08-2017, 11:02 PM   #84
whytry85
whytry85's Avatar
Found time the other day to start the gas doors. Cut out existing filler, wheeled a replacement panel and got it tacked in and planished. Ready to fully weld.
Instagram: Whytry85
Old 04-09-2017, 12:43 AM   #85
3drburb
You have some mad skills. Are you doing the 57 for yourself or a customer and what are you sanding your metal with?
Old 04-09-2017, 10:29 AM   #86
whytry85
whytry85's Avatar
Thanks man! I appreciate that! Im just an amateur compared to a lot of other folks. The 57 is for a customer. The truck has a lot of original patina but needed inner and outer lower door skins, lower fender sections, lower hinge pockets, and headlight brows. I tried to convince him to leave the patina how it was but he want the holes gone so here I am. Lol. I use a 2 and 3 inch green roloc bristle disc. It doesn't remove thickness of the metal but cleans it enough to get a proper scribe and weld. Then once the weld is planished, i use 80 on a da then follow up with 180 then a red scotch brite pad with Gibbs.
Instagram: Whytry85
Old 04-09-2017, 11:22 AM   #87
3drburb
Thanks for the reply. You can label yourself an amateur but me and the 57 owner would not.
Keep up that quality work and showing it.
Old 04-09-2017, 03:23 PM   #88
whytry85
whytry85's Avatar
You're welcome! And thanks for the kind words! I'll have some more pics of the rest of the truck this following week.
Instagram: Whytry85
Old 04-19-2017, 11:10 PM   #89
whytry85
whytry85's Avatar
Couple of pics of th side job 57 3100
Instagram: Whytry85
Old 04-21-2017, 08:44 PM   #90
3drburb
That 57 is sitting nice. Are you going to try and match the patina?
It's amazing the stuff you find in these old rides, mines had foil and steel wool in the 72 rockers.
Old 04-21-2017, 11:01 PM   #91
whytry85
whytry85's Avatar
It has a nice stance. Crazy to think it's just stock s10 suspension. We are gonna try to as best as we can. That's more of my buddies department.. lol I knew I was in for a surprise when I started the lower hinge pocket.. expanding foam out the butt.. lol
Instagram: Whytry85
Old 06-10-2017, 11:13 PM   #92
whytry85
whytry85's Avatar
Buttoned up the repairs on the 57 truck.. should be getting back on the c10 shortly hopefully. Also bought a 1984 swb that I'm gonna be using for a daily. Will post a seperate thread for it. Here's some pics of the 57...
Instagram: Whytry85
Old 07-01-2018, 12:25 PM   #93
Zero Clearance
Smile Re: Project: 3rd times a charm: 83 c10!
I registered just to be able to reply so i can bump this thread. Congrats with the new addition to the family. Great truck and hope to see how it turned out.
Zero Clearance is offline   Reply With Quote
Old 07-02-2018, 02:47 PM   #94
StarDust
StarDust's Avatar
wow, i barely started rust repair and it was impossible to get that good of fitment. good work
StarDust is offline   Reply With Quote
