Old 07-04-2018, 06:46 PM   #1
1968aj
gas cap question
I have searched but no luck. NEED VENTED GAS CAP FOR 72 C10 WITH STOCK GAS TANK. anybody have the answer? THANKS
1968aj is offline   Reply With Quote
Old 07-04-2018, 07:06 PM   #2
1968aj
Re: gas cap question
maybe I should explain more. truck has had a 5.3 swap. vent line on tank was used for return line. now I need to vent tank. 71-72 fuel caps are non vented. 67-70 are vented but the filler neck on tank is bigger so those caps wont fit my tank. has anybody else had this problem? how did you fix it?
Old 07-04-2018, 07:59 PM   #3
dayj1
Check out a 1972 c20 or c30 gas cap. The 3/4 ton and larger trucks were available without the emissions package and had vented caps.
dayj1 is offline   Reply With Quote
Old 07-04-2018, 10:08 PM   #4
1968aj
that should work if they have the same size neck as the 72 c10.
Old 07-04-2018, 10:29 PM   #5
1968aj
just went out and checked a c20 calls for stant 10623. it will not fit my c10.
