Old 07-05-2018, 02:37 PM   #1
FAKKY
AC options- LS swap to 57 truck
So like most people I *think* I'm going to have a clearance issue on passenger side frame for AC.
If I understand correct ....... Im going to need
1) a high mount adapter
2) a non variable compressor
Seems this will be a $500 switchout .... so just seeing if I have this right or other options ?
I'll also have to put the engine back in and get better measure - I am 'close' to being able to fit it in stock ... but unsure what clerance I need for flex and lines etc and have also heard of people notching frame.
Any good links/reads ?
thanks
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 07-05-2018, 07:41 PM   #2
Clyde65
Clyde65's Avatar
Re: AC options- LS swap to 57 truck
I believe Holly has some LS ac mounts that bring the comp in further.
https://www.holley.com/products/acce...y/parts/20-159
Also Dirty Dingo has one
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-05-2018, 08:23 PM   #3
FAKKY
Yeah - I read about that they offer the tightest fit in terms of width to help maybe gain a bit more ...... just not sure if it will be enough.
Sounds like some people are running the OEM variable displacement compressor also ......
So --- who has some real world details on what they like/used and why.
Or if not their own - just really good threads.
Old 07-06-2018, 09:57 AM   #4
Hart_Rod
Hart_Rod's Avatar
Holley setup...
Hart_Rod is offline   Reply With Quote
Old 07-06-2018, 10:22 AM   #5
FAKKY
Good Lord - swap trucks ^^^
Assume thats this bracket.
https://www.holley.com/products/acce.../parts/20-134P
So almost $500 between the bracket, pulley, belt and compressor.
Which AC system are you using.
Old 07-06-2018, 10:34 AM   #6
Hart_Rod
Hart_Rod's Avatar
Yes. VA Gen IV.
Old 07-06-2018, 10:44 AM   #7
FAKKY
Nice.
Really trying to see if there are options to use the factory compressor, I know there are arguments over variable versus static displacement.
Meaning ...... aware you can use a sanden/high mount to the tune of $500 ....... then add on the VA kit for $1k [underdash] to $1500 [surefit] just wondering what other options.
My AC will be tight on low mount - but it might fit.
Old 07-06-2018, 11:07 AM   #8
Clyde65
Clyde65's Avatar
I have mine on the stock bracket and compressor. 2002.
I use Old air Products and it all works great.
Clyde65
Rebuild of Clyde
support our troops!
Old 07-06-2018, 11:08 AM   #9
FAKKY
Good to know ^^^
Clyde is that in your build thread ?
Old 07-07-2018, 02:25 PM   #10
Clyde65
Clyde65's Avatar
The build thread on my signature is of my 69 Lo Liner Camper.
Clyde65
Rebuild of Clyde
support our troops!
Old 07-13-2018, 04:50 PM   #11
FAKKY
Hart Rod/Clyde65 - do you guys have a explanation on the wiring.
Seems most of the setups are
1) PCM controlled for 1 or 2 fans to activate on off (in pcm with hptuners etc)
2) When you add AC you need a way to control the activation of fans when compressor cycles ..... so a trinary switch
Sound right ?
Whats that look like - how did you do yours.
Old 07-13-2018, 09:13 PM   #12
Clyde65
Clyde65's Avatar
My AC isn’t pcm controlled at all, it’s stand alone like with my SBC . I have a tri-nary switch for the fans one runs at 185-190 and the other one comes on with AC or 205( I think)
Clyde65
Rebuild of Clyde
support our troops!
Old 07-15-2018, 02:00 PM   #13
FAKKY
Dang.
Thanks.
Yeah I think the LS swap allows PCM control of the fans.
From LT1SWAP
Fan Controls 1,2 - GM PCM's typically will control electric fans, usually 2. The PCM will supply the (negative) or GROUND signal to turn on fan relays. YOU CAN NOT DIRECTLY CONNECT PCM FAN CONTROL WIRE TO FANS
Pin 33 FAN For Fan replay control #2
Pin 42 FAN For Fan replay control #1
Not sure what exactly that looks like.
Basically trying to decide between
https://www.summitracing.com/parts/d...xoCDi4QAvD_BwE
or
Using a prebuilt relay harness similar to two fo these
https://www.bp-automotive.com/produc...an-or-nitrous/
and then wiring correrctly ...... given AC signal wire also.
I think the dakota options is my best bet , along with a trinary switch for AC.
Old 07-17-2018, 09:40 AM   #14
Hart_Rod
Hart_Rod's Avatar
Sound right ?
Depends on the year of the computer setup, but most will control the fans based on temperature of the engine. Some will kick on the fan when you turn the a/c on. But most require you to wire in a binary or trinary switch.
Old 07-17-2018, 12:33 PM   #15
FAKKY
Yup - thats the part aftyer more info - got a link or more detail ?
*think* it something like
a) Set both fans to come on at say 180 degress in PCM file
b) Set Fans to both com on also when compressor is enaged via trinary switch
But not sure how .....
1) This is wired up
2) How its done if you use both fans at same time or hi/low
3) What other considerations etc
Old 07-18-2018, 09:29 AM   #16
ls1nova71
ls1nova71's Avatar
If you already have PCM controlled fans, then just tie the trinity switch ground output to the high side fan output from the PCM. This will trigger the relay by the trinary switch or the PCM. It may cause a check engine light, but the error reporting can be tuned out.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-18-2018, 11:11 AM   #17
FAKKY
Dont have anything yet - just planning forward.
