Old 07-07-2018, 09:43 AM   #1
Art portet
1972 GMC Long bed lowering problem
I lowered my 72 GMC longbed 3 inches front and back. Used blocks and 4 degree shim on rear. I am hearing a chirping sound from I believe the carrier bearing. Rear driveshaft is tight against bearing. Should I soften the shaft and if so how much?
Art portet is offline   Reply With Quote
Old 07-10-2018, 07:04 AM   #2
PGSigns
PGSigns's Avatar
Re: 1972 GMC Long bed lowering problem
A 3 inch block is to much in my opinion. Blocks move the rear forward (on trailing arms) and I assume that is what you have since the shaft is binding up. You can cut it but the best way to do this would be a set of 3" springs. 4 degrees is a lot for just a three inch drop. Have you checked the u-joint angles?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-10-2018, 07:09 AM   #3
Art portet
I will look into buying springs and getting rid of the blocks. Seems like the springs will push things forward as well to some degree.
