07-08-2018, 06:58 PM | #1 |
4x4 parts / th400/th350 cross memebrs and more
I was going to build a 4x4 but switched gears and now going 2 wheel drive , I purchased some parts from a member here.
I would like to sell the 205 case and adapter together they are set up for a turbo 400 np205 empty case that has been machined for a th400 for the 90mm bearing has been sandblasted and painted and a original 67-72 adapter for TH400 ( i have another complete NP205 case with internals from a turbo 350 that will fit in the new case, you would just need to buy a few extra parts. empty NP205 case with adapter $400 ( $450 with the complete case for the internals, ) Transfer case to frame mount/brace $75 powder coated trans/transfer case cross member $250 with the frame mount brace a second cross member has not been cleaned with rubber mounts for a turbo 350 $125 A used power steering gear box has not been cleaned $75 engine cross member $100 has not been cleaned NP 205 shifter boot and ring $75, boot has no rips, ring needs paint disc brake front dana 44 with 373 gears, needs rotors and bolts and bearings, it has been disassembled except for the gears $250 or will sell parts off it. I will ship so items are plus shipping if I am over priced on some things let me know. Last edited by my kids toy; 11-13-2018 at 04:34 AM. |
07-08-2018, 07:02 PM | #2 |
Re: 4x4 parts / th400/th350 cross memebrs and more
07-08-2018, 07:12 PM | #3 |
NP 205 boot and ring $75
07-08-2018, 10:39 PM | #4 |
I loved Grand Haven when I lived there in the late 80s. The area has built up so much since then. The off shore powerboat races and Coast Guard festival were a blast. Nice parts.
07-21-2018, 04:06 AM | #5 |
A couple things might be over priced so shoot me a offer.
07-21-2018, 05:42 AM | #6 |
Hi, rebuilt power steering gear box? More information? 4x4? Pictures? Interested. Thanks
07-21-2018, 07:42 AM | #7 |
Jimmer1964 I am sending a pm and yes it is a 4x4
07-21-2018, 10:47 AM | #8 |
Does the 400 adaptor come with the coupler
07-21-2018, 01:23 PM | #9 |
I am not sure, I bought this from a member here and was told it would take $250 in rebuild kit and shaft to finish it, I was going to build a 4x4 but am now building a 2 wheel drive.
07-22-2018, 12:51 AM | #10 |
Hi. I am interested in the front drive shaft in picture #4 shipped to 90713. Thank you.
07-22-2018, 06:09 AM | #11 |
Sorry the drive shaft is not for sale right now.
07-22-2018, 08:20 AM | #12 |
The th400 adapter doesn't use a coupler like the other transmissions. The male th400 transmission output shaft goes straight through the adapter and connects to the female np205 input shaft.
A np205 case originally behind a th400 will use a bigger input gear bearing and therefore is bored a larger diameter...as mentioned in the third link. Here is some good info on the subject : http://offroaddesign.com/catalog/NP205tech.htm http://offroaddesign.com/TH400Tech.h...smission_case: http://www.fourwheeler.com/how-to/tr...e-made-better/ |
07-22-2018, 08:28 AM | #13 | |
The adapter pictured appears correct for adapting the th400. It would not have needed any machining. If anything was machined, it likely was the np205 case's input gear bore... Should be 90mm when behind a th400. Stock 67-72 np205s were 80mm. |
07-22-2018, 08:34 AM | #14 |
Thanks 402bowtie for the help. yes this has been machined for the 90mm
07-23-2018, 12:00 AM | #15 |
Thank you for the reply. If you do decide to sell the drive shaft in the future, please keep me in mind.
07-23-2018, 01:35 AM | #16 |
Will you take $150 for the adapter?
07-23-2018, 01:38 AM | #17 |
My zip code is 90670
07-23-2018, 05:08 AM | #18 |
Sorry but no thanks.
07-23-2018, 09:09 AM | #19 |
I’ll take the empty case and the adapter for the $200. 6263152573
07-23-2018, 12:55 PM | #20 |
The empty case is $200
The adapter is $200 I would like to sell together unless 2 people want each part. Last edited by my kids toy; 11-13-2018 at 04:36 AM. |
07-23-2018, 01:36 PM | #21 |
My mistake I thought you wanted $200 for the adapter. Maybe I misread
07-23-2018, 01:54 PM | #22 |
Give me a deal for both and I’ll take them.
07-23-2018, 07:54 PM | #23 |
I think $450 is a deal, bowtie wants $300 for his adapter
07-23-2018, 08:14 PM | #24 |
I think $450 is a bit more that i can afford. I’ll can offer you $300.
07-31-2018, 07:42 PM | #25 |
Ttt
