07-11-2018, 02:31 PM | #1 |
Gauge questions
Hey guys,
Thanks to you guys, I got the correct temp sending unit from lectriclimited, and that is one more functioning factory gauge! The last one to get functional is my oil pressure. Since the 64 one is the mechanical gauge (I think?) I can't wire it up to the electrical fitting on the back of my intake manifold. (Truck was stock 6 cyl, the motor is a 327.) Any ideas on getting the stock gauge to work with the newer motor? I'm kinda lost on how to convert anything over to that. And as usual, the tight budget (free>real cheap>probably not going to happen,) is my process of elimination lol. Thanks fellas!
Been a crazy 2018. Moved twice, back HOME in Oregon. Now to put everything back together, including the truck... My build thread for "Rocket" - http://67-72chevytrucks.com/vboard/s...d.php?t=753023 |
07-11-2018, 04:09 PM | #2 |
Moderator
Re: Gauge questions
As I recall there is a plug on the back of your small block, behind the drivers side head for the oil pressure. You get a new oil gauge line kit and install it at gauge end and engine end. Maybe it was next to the oil filter boss?
Cutting oil pressure line - http://67-72chevytrucks.com/vboard/s...d.php?t=705484 Location of oil block connection - http://67-72chevytrucks.com/vboard/s...42&postcount=5 Is that what you were asking?
07-11-2018, 05:06 PM | #3 | |
Re: Gauge questions
As for the links you provided, I haven't ever really looked at that part of my motor, so I will be doing that today to see if I can find it. As far as my gauge, I would just use the stock gauge, and get an oil gauge line kit? Does it have to be copper line? I see a few online that are braided lines. Sorry for so many questions. I just want to keep the gauges as stock as possible. Thanks for the reply and input Rod!
07-11-2018, 09:17 PM | #4 | ||
Re: Gauge questions
Braided line can be used with some mechanical oil pressure gauges, but you will probably run into issues finding adapter fittings to hook it up to the back of the stock gauge. That's because the original gauges used a compression sleeve nut connection as shown in LockDoc's post in the first link Rob provided. Those sleeve nuts are designed to fit directly over 1/8" OD tubing and then screw directly into the back of the stock gauge. |
07-12-2018, 12:26 PM | #5 |
Re: Gauge questions
Ok so then that unit where I mentioned could be an oil pressure sending unit? Even if it is, there is no way to hook up that unit to my gauge, since they are different types I'm guessing.
Sounds like the best bet is to just get a copper tube kit and run it from the port where Rod said, into the back of the gauge.
07-12-2018, 06:58 PM | #6 | |
Re: Gauge questions
Yes, that would be the easiest way to hook up the stock gauge. Just be aware that not all copper tube kits will include the correct compression sleeve nut that fits the back of the stock gauge. That is available separately as Weatherhead #6100x2 or Edelmann #111200. Or, I think I remember seeing a post where LockDoc was selling copper tubing kits that included all of these OE type nuts & fittings. |
07-12-2018, 10:42 PM | #7 |
Re: Gauge questions
The line to the gauge was actually steel and is probably still hanging around. Look at the back of the gauge and follow it to the firewall, then the other side. You may just need a $2 fitting to connect it.
07-14-2018, 07:41 PM | #8 |
Scrapper 1
Re: Gauge questions
Lets see if i have a pic of all V8 motors that had the oil pressure hole and metal tube tube did my best the old 327 shows that it was there remember to block off the road draft tube with a freeze plug
