Air Intake Support
What are you guys using to support your air intake setups (non-stock). I'm trying to figure out the best way to support a 4" pipe/k&n setup. I got a nifty spectre kit that was advertised as fitting a 4" pipe but the loop it used to hold the pipe was only 4" (exact same diameter as my intake pipe) so it didnt work.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
![]() ![]() Join Date: May 2015
Re: Air Intake Support
I used a piece of the intake pipe and built a cradle to support the tube...hose clamp around it holds it solid...the cradle bracket bolts to the core support....
I'd appreciate a pic of that if you have one and have time.
I made it from aluminum and painted it black....i put a piece of blue tape on it so you can see it better....and of course the pics are upside down
meowMEOWmeowMEOW
I riveted a little hook on the end of intake pipe and hooked it into my core support (my core has a hole in it for the intake to fit through.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I made an aluminum support that bolts to the core support and to a small tab I welded to the intake tube. I just picked it up from powder coating today so Ill get it installed and take a pic tomorrow.
My intake is on the passenger side . Picture is a little dark but if you study on it you will see one mount point on the head and another forward of it on the belt tensioner bolt . Both points come to a Y then to the intake . I had a small flat thin piece I hammered into the size of the intake tube and welded a couple tabs to put a bolt in . Doubles as a MAF harness holder . The rods were a couple fender support rods I cut up . Just stuff I had laying around .
I used a kit from Spectreperformance.com that allowed me to bolt it to the radiator support.
https://www.spectreperformance.com/s...aspx?prod=9702
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
#9 | |
#10 | ||||
Dang. Looks like nearly everybody is having to fabricate something. I'll do some more digging and see what I can figure out. My ability to fab something that I will be HAPPY with is pretty limited. Got some stuff at work I can mess with but it'd probably look more at home on a tractor than on my hot rod.... thanks guys- I really appreciate the input
