Old 07-13-2018, 12:09 AM   #26
Root2812
Root2812's Avatar
Re: Engine placement help
Originally Posted by obie16 View Post
Hey guys thanks for the help!! It’s helpful to see all the different set ups! Root? Is that the high mount holly system, I liked the way the holly mid mount was set up but I’m not running a/c, so that system won’t work, did you look into the low mount system? Again thanks everyone!!
I used this.
https://www.holley.com/products/ls_p...y/parts/20-135
I didn't buy the whole accessory drive kit from them, just the bracket. Their instructions lists all the Gm part numbers you need to buy the other stuff. I shopped around for all the other stuff for it.
I didn't look at the low mount system. I picked this one because it was the same as the corvette accessory drive so not only does it give me more front clearance but it also puts the alternator in the right place to fit my fuel rail covers.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 07-19-2018, 03:25 PM   #27
FAKKY
Im having a hard time with those pics seeing if there is a real issue - or am I missing it.
Seems like if the radiator was brought forward like HRD' pics ... then it should fit.
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
