Old 07-13-2018, 08:31 PM   #1
bean
Who has a kill switch in their truck?
I am going to put one in my 72 and just curious who all has them. Where did you put it and what's the best way to wire it? Thanks
bean is offline   Reply With Quote
Old 07-13-2018, 10:04 PM   #2
bill3rail
bill3rail's Avatar
Re: Who has a kill switch in their truck?
What are you trying to do? Kill engine while it runs away on you? Secret ignition kill to make sure nobody can start it without knowing where this switch is?
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-13-2018, 11:04 PM   #3
dmjlambert
dmjlambert's Avatar
Well then we can't talk about it without revealing to the crooks how it works!
This guide has some fun ideas. http://www.davebarton.com/pdf/RelayGuide.pdf
Old 07-14-2018, 12:22 AM   #4
bean
Trying to keep it from being stolen
Old 07-14-2018, 06:38 AM   #5
72LB
72LB's Avatar
I have one but aren't telling where , I have one of the switches that has a removable key.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 07-14-2018, 06:42 AM   #6
Grumpy old man
Grumpy old man's Avatar
Move to the country living in a big city must increase the chance of them being stolen by a lot , Not many trucks stolen around here it's too likely you'd be shot or eaten by the dogs ,People in the country don't have little dogs as pets out here they have to work for a living and bark at anything that comes close to the house or driveway . If their not good watch dogs we sell them to the city dwellers
Old 07-14-2018, 08:51 AM   #7
dmjlambert
dmjlambert's Avatar
Yes, thanks for the nice dog in the city! When our doorbell rings, the dog goes into a tizzy and starts wiggling her docked tail so fast it's a blur, and runs for the front door and squeals with delight. She can't wait for the person to come in and pet her.
Old 07-14-2018, 08:57 AM   #8
mr.precision
mr.precision's Avatar
I had one on my '66. Hidden switch that grounds the ignition coil. Years ago I was concerned someone would steal it out of a parking lot. Short bed fleetside big window custom cab with original 2 tone green and white paint. Wish I'd never sold it.
mr.precision is offline   Reply With Quote
Old 07-14-2018, 09:05 AM   #9
Grumpy old man
These work and it helps to throw a large bone in the yard by the gate
Old 07-14-2018, 09:19 AM   #10
Larry Weaver
Here is what I did with mine.Bought a 3 way toggle switch (center is off) a new wiper switch knob. Had to enlarge hole on knob.Down is power on, center is off and if some one happen to twist it just spins.Was just a GM plug in hole before. Wired to HEI dizzy.
Larry Weaver is offline   Reply With Quote
Old 07-14-2018, 09:24 AM   #11
Larry Weaver
Sorry, knucklehead at the computer.this is the off position.
Old 07-14-2018, 09:57 AM   #12
dmjlambert
dmjlambert's Avatar
What is the wiring like to the distributor? Do you short the tachometer terminal to ground, or do you interrupt the voltage to the power terminal?
Old 07-14-2018, 10:28 AM   #13
jonmc56
jonmc56's Avatar
Some good ideas in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=474293
'69 C10 CST
'68 Chevelle Malibu
My 69 CST Build Thread
jonmc56 is offline   Reply With Quote
Old 07-14-2018, 12:17 PM   #14
bigdog55
bigdog55's Avatar
I installed a propane system on mine. So I can run gasoline or propane. I have a toggle switch that goes from one to the other and there is a spot on the switch that the truck won't get fuel from either and the truck will not run. So in a way it's a built in kill switch.
Brian
bigdog55 is offline   Reply With Quote
Old 07-14-2018, 12:41 PM   #15
dmjlambert
dmjlambert's Avatar
The best kill switch would be one that if not switched on it would still allow the truck to be started, but then would sputter and die after 5 to 10 seconds, try again same thing happens, and then would not start at all the 3rd and subsequent attempts. On the 4th attempt, perhaps a hefty amperage relay could short to ground the passenger fender-mounted battery terminal and burn up the fusible link, resulting in smelly smoke coming out from under the hood. Combined with locking the hood to prevent troubleshooting, all that would spoil the mood of a casual thief.
I wonder if anybody has made a modified steering column that locks into position under the hood instead of inside the cab. Turning the steering wheel all the way to one side and then locking the column under a locked hood using an electric actuator would deter. It's probably not possible to make them commercially and sell them, because any modifications at all to steering would result in the maker getting sued successfully if the steering lock activated during driving, and you can't put in enough double safety mechanisms.
I have heard clubs are no deterrent at all, because the thief just saws through the steering wheel in a few seconds and bends the wheel it to remove the club. Steering wheel is easily replaceable.
Old 07-14-2018, 12:45 PM   #16
Larry Weaver
I just interrupted power wire to dizzy.
Old 07-14-2018, 01:01 PM   #17
Getter-Done
Getter-Done's Avatar
The Ignition is my first choice to disable (Distributor).
Like some have said above fuel system is a good choice depending on your type of fuel system.
Making a shield over the solenoid would deter a quick(Hotwire & screwdriver bump start).
I think one of the biggest things that would slow them down is a hood latch cable like the one below. Key is to mount it in a not so normal place.
I had a set up on my 63 impala and most people could not open the hood (Quickly anyway).
https://www.classicindustries.com/pr...ts/hr1100.html
This link is just an example.
There are others available.
84 Chevy K-20
Old 07-14-2018, 03:50 PM   #18
rockyrivermark
I have four switches under dash. In plain site. . Each has 3 positions
Switch one. Horn goes off in up and down position. Middle position is off
Next switch brings power in and to 3rd switch which then goes out to HEI.
4th switch is tied to neutral safety switch.
So basically you have a combination lock of switches.
Also added crimestopper alarm system with door actuators for under $80
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 07-14-2018, 05:56 PM   #19
el_fantasma
el_fantasma's Avatar
It’s located on a small shelf under the dash near the steering column and it turns off the ignition. In other words, the engine cranks but won’t start. I also have a battery cut off that works with a FOB. Its turns off everything electrical which is handy when I leave the lights on.
72 White Cheyenne, The Ghost
el_fantasma is offline   Reply With Quote
Old 07-14-2018, 06:18 PM   #20
stsalvage
Scrapper 1
stsalvage's Avatar
Its Sad that we have to go to these measures now days.It use to be so nice.if you drive a really trashy looking truck most people will stay away from it a few will look at it but the thief's feel like it will brake down on me.An if they are caught stealing a peace of crap.They will get a beat down
stsalvage is offline   Reply With Quote
Old 07-15-2018, 04:18 AM   #21
dflarsen77
Active Member
That Dave Barton guide is really cool! All the stuff about how to make a simple alarm and the old cellular car phones are pretty fun.
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline   Reply With Quote
Old 08-23-2018, 02:31 PM   #22
67chevemall
67chevemall's Avatar
I use aircraft wire to dangle down from hood and lock it to the pass side sway bar mount.
And a switch on the dizzy wire.
Camera at night with motion light and loaded shotgun for the Crack heads invading Niagara.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 08-23-2018, 07:33 PM   #23
jeffahart
jeffahart's Avatar
No No No Grumpy No! You're not thinking like a Lawyer!
You get robbed and Dog bites robber... you get sued for everything you own.
You get robbed and you shoot robber... you get sued for everything you own.
You booby trap robber in it gets hurt... you get sued for everything you own.
Further... there are now Robbers & Burglars Unions. In Los Angels it's Local 4311FUTAXPAYER.
The Union rules for Local 4311FUTAXPAYER (Follow them or be subject to California penal codes).
1) Your home must be clear of all clutter and debris so not to impeded with Lawful robbery of your home.
2)You must have available a dolly for items over fifty pounds. Union contacts state: no one burglar may lift items over fifty pounds; and two burglars items over one hundred pounds. Section two of that code: a dolly must be maintained in working condition. Failure to do so, is considered impedance with Lawful robbery of residence or business.
3)Any fake silver or costume jewelry MUST be clearly labeled in a separate container or box. To include: small item collectibles. All antique furniture must be clearly labeled with current market value. It is not the Burglars responsibility to access the values of property during the Lawful robbery of a residence.
Breaks and work hours.
1) If your home is robbed and the thief cannot complete the job in six hours, the thief has 24 hours to return and complete the burglary. Homeowner may not disturb any items in the home until the 24 hour grace period has lapsed.
2) Pre-made meals must be kept in the ice box for lunch breaks. Frozen dinners do not count.
3) All drinks snacks and juices MUST be organic.
Failure to comply with statues will result in prosecution of unlawful taxpayer.
Oh, opps I left one out. If robber shoots you and misses, he get's and alibi fire. You have to stand still like a dope and them shoot you!
Yep, I think I covered the basics of... bend over, pay your taxes and shut up!
j
White K20
jeffahart is offline   Reply With Quote
Old 08-23-2018, 07:59 PM   #24
AussieinNC
Moderator
AussieinNC's Avatar
My "kill" system is comprised of the following:
A mini video camera mounted facing the drivers seat
A cell system based alert that captures the thief's face, calls my cell and uploads the video to the cloud
The ignition system is locked out as is the starting system
Fuel system is shut off (electric pump)
Door locks lock and power windows lock out so they cant be put down
Digital map display shows countdown to detonation of knock out gas inside cabin
If all this fails and the truck is somehow started and driven, a digital sign under the tailgate displays a "Help Me, I have been kidnapped!" warning plus GPS tracking is enabled and trucks position down to 3 feet is sent to my phone.
Anyone want to try and get into my workshop ?
I have Gus and George, and both are always hungry....!!!!
Plus...lil ol Nellie is always close at hand...Love NC concealed carry laws....
AussieinNC is offline   Reply With Quote
Old 08-23-2018, 08:26 PM   #25
Steeveedee
Who Changed This?
Steeveedee's Avatar
I have an account with the NSA to track my vehicles if they get stolen. [front door breaks down, "Hey, WAIT, I'm just surfing the internet!"]
~Steven
Simi Valley, CA
