#5551 |
![]() Join Date: Aug 2014
Re: Restoring Rusty
is this dude for real?
#5552 |
Moderator
![]() Join Date: Oct 2008
Re: Restoring Rusty
He's smokin something real good... LOL
That bullet speedometer driven gear carrier is the same as the TH350. Usually they're pretty worn out. They're bloody cheap. The gears to tire size and axle ratio cheat sheets are in the parts books. The GM automobile parts books are on Ian Hardings' site GMPartsWiKi.com
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 07-15-2018 at 07:50 PM. |
#5553 |
![]() Join Date: Jul 2000
Re: Restoring Rusty
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#5554 | |
Re: Restoring Rusty
#5555 | |
Re: Restoring Rusty
"We don't know when or if this item will be back in stock." no worries I found one on eBay, bidding, fingers crossed |
#5556 |
Re: Restoring Rusty
Whoops!
I hope you win the bid w/o spending too much. Hey, how about this? https://www.mscdirect.com/product/details/06847388
#5557 | |
Re: Restoring Rusty
#5558 |
Re: Restoring Rusty
so Pontiac Mike hooked me up with this handsome Mr. Gasket T handle, daddy likes, didn't quite dig it on my previous stick but it works on the goose neck
whacha all think? Last edited by Gregski; 07-17-2018 at 03:46 PM. |
#5559 |
That'll work.
#5560 |
Re: Restoring Rusty
Works for me
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#5561 |
Re: Restoring Rusty
That's T-rrific!
Romans 10:9 - The Truth |
#5562 |
Re: Restoring Rusty
#5563 |
Re: Restoring Rusty
#5564 |
Re: Restoring Rusty
#5565 |
Re: Restoring Rusty
Well how does it drive, how does it shift, do you like it?
I like this transmission very much, it shifts very nicely. One note to make is that no matter how hard it is to shift on the bench, ie when you have it out of the truck, that is not how it is going to shift when bolted up to an engine with that long lever of a shift stick, it actually shifts easily when installed on the truck However I'll be honest with you as always, I replaced one used Craigslist transmission that was making noises with another used Craigslist transmission that makes different noises, LOL! It's fine and normal in Reverse and 1st gear, but as soon as I shift it into 2nd it starts to make a rattling noise, as if there was a loose bolt in the case just bouncing around (that's the best way I can describe it) and continues to make the same rattling noise in 3rd and 4th gears as well as in neutral when rolling. ![]() |
#5566 |
Moderator
Re: Restoring Rusty
Input shaft center support needle bearing or the cluster gear needles make noise in the Saginaws.
GM only used two rows of needles inside the cluster gear in the Saginaw 3 & 4 speeds vs four rows in most other transmissions so the countershaft and cluster gear sometimes wear badly. Not difficult to repair as long as the cluster gear isn't knackered. If you like that transmission fix it before it strips the teeth off the input shaft or the cluster gear or both. The GM NP440/A833 MY6 is a more robust light duty transmission than the Saginaw. The only real gotcha is the countershaft bearing wearing the aluminum case hole oval. It can be repaired. Chrysler used the AL case A833 in racing applications with steel bushings in the countershaft bores that were tight press-fit to the case and loose press fit to the countershaft. Not just any Joe with a Bridgeport is going to be able to pull this off. I am not capable of setting up this level of precision boring. I can make bushings within 0.0005" on my small lathe but aligning a worn case on my Gorton 9J table or dogged to the carriage on my big lathe so the shaft holes can be bored in-line and concentric with probably only four to six points of reference (two to three per hole) left of the original bores is not a task I'm willing to undertake. https://www.hotrod.com/articles/mopp...-case-buildup/
And please let us know if and how your repairs were successful. Last edited by hatzie; 07-19-2018 at 11:27 AM. |
#5567 | |
Re: Restoring Rusty
I work in IT (Information Technology) so sometimes we work while you sleep ie in the off hours and weekends, ha ha so this weekend is hell weekend so no time to wrench |
#5568 |
Re: Restoring Rusty
So Gentlemen, what is the best part about driving your truck around without putting the transmission tunnel back on?
#5569 |
Re: Restoring Rusty
Took me a minute, but I'm assuming you mean the in-cab bump that bolts over the transmission? I would think you would get to enjoy all kinds of things like increased road noise, dust particles, heat, engine noise and a malodorous combination of antifreeze, exhaust and engine oil. But maybe that's not it. I'm dying to know what I missed.
#5570 |
Re: Restoring Rusty
The suspense is mounting....
#5571 | |
Re: Restoring Rusty
As you all may recall from years ago The Greg cleaned his bellhousing to Full Metal Jacket drill sergeant standards... well it and the trans have gotten greasy since and he's been scratching his head going where is the leak coming from, it don't smell like trans fluid, it don't taste like trans fluid, it don't feel like trans fluid so put on your best fittin' Sherlock Homes hats and note the distinguished drip down spread pattern on either side of the bell and dry as Sahara in the middle |
#5572 |
Re: Restoring Rusty
#5573 |
Re: Restoring Rusty
so the hood lift we shall, and to quote any Middle Manager "let's take a deeper dive" ha ha
well what do we have here, let's start with the passenger side shall we... let's see if we can fly this camera equipped drone in a bit closer ... aka ... zoom in well that's a mighty fine oil puddle there in the intake manifold bolt valley if I do say so myself |
#5574 |
Re: Restoring Rusty
and the other side please...
#5575 |
Re: Restoring Rusty
so my original thought was leaky valve cover gaskets, but I am running brand new rubber ones with a liberal coating of gasket sealer on them for good measure, plus when I looked, felt, examined the valve covers I noticed there was oil on top of the valve covers, which then led me to look in / on the intake manifold
so I know I am using generic grade 5 hardware store bolts to hold down the intake manifold with generic washers to boot, would using some proper intake manifold bolts such as the ARP ones made from unoptanium remedy this issue? - (I'm looking at you HATZIE) ha ha |
