Old 07-19-2018, 10:30 AM   #1
First c10
First c10's Avatar
D99 paint divider trim
Hey guys,
I want to put the D99 paint divider trim on my truck that is below the rear window. I have seen a few threads on it but cant find how to attach the little studs that hold the clips on to hold the trim.
I have a parts cab with the stud on it for locations but not sure what to use or how to attached them to the my cab that did have them from the factory.
Any help would be great.
Scott
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 07-19-2018, 10:43 AM   #2
B. W.
B. W.'s Avatar
Re: D99 paint divider trim
Two options:
1. weld on studs using a body stud welder with a special attachment
2. screw on studs
B. W. is offline   Reply With Quote
Old 07-19-2018, 11:07 AM   #3
First c10
First c10's Avatar
Originally Posted by B. W. View Post
Two options:
2. screw on studs
Thank you for the options. Do you know where I could order the weld on studs?
Or even the screw in studs? Could you even pop rivet them on?
GO GO!!!
Old 07-19-2018, 12:32 PM   #4
clay68c10
clay68c10's Avatar
Most body shops have the stud welder and could do it for you. If you mark out where the studs go it would be a quick job and probably not cost much.
There are the screw in type, but that's a lot of holes to worry about rusting.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-19-2018, 12:42 PM   #5
Grumpy old man
Grumpy old man's Avatar
If the truck is already painted use the screw in type or pop rivits if it hasn't already been painted you could use the weld on studs .It's not cheap to have them installed .
Old 07-19-2018, 12:50 PM   #6
Bigdav160
Bigdav160's Avatar
I am not familiar with the trim clips. Are they this type of stud?
If so they were used on a lot of GM trim especially front and rear glass trim.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-19-2018, 12:53 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Yes
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-19-2018, 01:43 PM   #8
FRCvette
So where would one get these screw in studs and the molding?
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 07-19-2018, 01:55 PM   #9
FirstOwner69
FirstOwner69's Avatar
Classic Industries sells them. I assume other suppliers do as well. Maybe even your local Chevy dealer.
Here's the Classic Industries link.
https://www.classicindustries.com/sh...rts/?q=4492963
FirstOwner69 is offline   Reply With Quote
Old 07-19-2018, 03:53 PM   #10
First c10
First c10's Avatar
I have the stud welder just need the actual studs. Does anyone know where to get them. I have looked but am not sure even what they are called.
Thank you
GO GO!!!
Old 07-19-2018, 04:15 PM   #11
Grumpy old man
These are a lot easier
scroll down page
https://www.txdashcovers.com/blripintywcl.html
Old 07-19-2018, 04:58 PM   #12
StingRay
StingRay's Avatar
Any Autobody supplier will have them. a Unispotter stud gun comes with the studs and the tip to put them on. These are a common thing. And they will never leak.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 07-19-2018, 05:08 PM   #13
First c10
First c10's Avatar
Wow. Ok guys Thank you for all the suggestions
I think I would go with the river idea instead of screws. But want to weld them if possible. I will stop by my local body shop as see if I can buy a dozen or so.
Thanks again. I will post a picture of what I do. Before and after!
GO GO!!!
Old 07-19-2018, 05:38 PM   #14
First c10
First c10's Avatar
H&S or unispotter # 1003 is what looks like I need. But I don’t need 500 of them. And the adapter is about $30 Anyone have the adapter I can borrow and a dozen or so of these rivets?
GO GO!!!
Old 07-19-2018, 06:02 PM   #15
Grumpy old man
To use a stud gun you need an 1 1/4" of bare metal around each stud you intend to apply ,They have to be perfectly straight and then you have to deal with doing body work around each stud which is a PITA , if you don't get good adhesion when spotting them on they can come off usually when your finished with paint and installing the trim. It's much easier to align your trim /drill your holes and then finish all your paint work , Slide the plastic molding clip onto the rivit stud and THEN rivit them to your truck . if you worried about rust use some flow grade sealant on each one prior to installing .
The problem with the screw in studs is they are a #1 phillips head screw diver and if your driver doesn't fit really good to the screw they can easily slip leading to paint gouges and scratching
This is why the rivits are easiest /faster and less expensive .I have 2- 67 cabs I'll be fitting trim to this next week if you need pictures ,
Old 07-19-2018, 08:44 PM   #16
FRCvette
[QUOTE.I have 2- 67 cabs I'll be fitting trim to this next week if you need pictures ,[/QUOTE]
I am in for pics.
2004 SSR
2013 Silverado swb
Old 07-19-2018, 08:54 PM   #17
First c10
First c10's Avatar
GOM. Everything I have read is pretty much Word for Word what you have wrote on this post regarding these types of trim secure points . I agree with you about the rivets but I want to weigh all the options. I don’t like the screws and if I can weld them on with certainty that they will remain that’s the best option. But definitely faster with the rivets. I think I am going to order the rivets and test it out on some sheet metal. Thank you
Also I am down with pictures of you for kind. I will post a link to the weld on drugs and the adapter just in case someone at a later date reads this.
Thank you guys!
GO GO!!!
Old 07-23-2018, 07:43 PM   #18
First c10
First c10's Avatar
Grumpy any updates on trim mounting?
I ordered set a rivets hopefully they’re in this week I’m ready for paint!!!
GO GO!!!
Old 07-23-2018, 07:52 PM   #19
Grumpy old man
I'll get some pictures posted tomorrow , It's easy .
Old 07-26-2018, 12:29 AM   #20
First c10
First c10's Avatar
Hey guys.
I got the trim out and got it marked up on the cab. I was able to get the info off the parts truck.
The ziplock bag was $32 for 20 rivets. Crazy right?
The rest are pictures of the studs riveted on. It was easy after the locations were found.
I did add a little seam sealer to the rivet before I crimped them in.
GO GO!!!
Old 07-26-2018, 10:42 AM   #21
Grumpy old man
it looks like you got it ! You may want to cover the studs before paint so the clips which fit tightly will slide on easier ,Leave the tubing about 1/16 off the body of the truck so it just covers the stud but allows paint at the base .
http://www.beldenspeed.com/beldenspe...epop-rivettype
Old 07-27-2018, 01:03 AM   #22
57taskforce
All about them K’s
57taskforce's Avatar
Thanks for posting about the rivets, I had seen the screws before but wasn’t crazy about them. All the studs were cut off my cab by a previous owner. I’m subscribing to this thread so I’ll be ready when I put my trim back on.
Tyler
57taskforce is online now   Reply With Quote
Old 07-28-2018, 10:06 AM   #23
72bowtiestepper
Subscribing also....I like those pop-rivet studs better than the screws.
72bowtiestepper is offline   Reply With Quote
Old 03-18-2020, 01:24 PM   #24
Stover93
I'd like to add this trim to my cab also. It looks like it centers on the bottom edge of the drip rail??
Stover93 is offline   Reply With Quote
Old 03-18-2020, 04:36 PM   #25
First c10
First c10's Avatar
I actually placed mine so the bottom of the chrome trim will stop right at the bottom of the drip rail. I am about ready to put the trim on after paint, So thank you for reminding me about this thread!
GO GO!!!
