Old 07-21-2018, 02:19 PM   #1
macdaddy70
Little help here
Started a steering wheel refurb and while in there I decided to change the broken Red hazard switch. After installing I attach the 2 harnesses and horn goes off. I unplug horn, but relay is still energized of course. Would this be normal? What do I need to check? I have not installed the wheel, this is as far as I have gotten with the re-assembly.
macdaddy70 is offline   Reply With Quote
Old 07-21-2018, 02:41 PM   #2
ncpetersc
ncpetersc's Avatar
Re: Little help here
I just read a thread about something similar after a turn signal install I think. Look for something in the assembly shorting out. I'll try to search for the post.
Found an older thread:http://67-72chevytrucks.com/vboard/s...d.php?t=278525
This is the thread I read recently: http://67-72chevytrucks.com/vboard/s...highlight=horn
ncpetersc is offline   Reply With Quote
Old 07-21-2018, 02:52 PM   #3
macdaddy70
thanks. Been reading some older posts and I found out the black wire may be the culprit. I will pull apart to see if ir ot other wires are grounding against the metal column. I did have an issue with the harness...may have pinched a wire.
