Old 07-23-2018, 10:13 AM   #1
bad 71 chevy
bad 71 chevy's Avatar
Fixing a lock
Problem someone tried to drill/punch out my drivers side lock whats the best way to be able to keep my same key get a used lock cylinder and get it keyed to match? or buy a new re-manufactured one, i have read that the remans dont fit the best in the old handles. Thanks in advanced.
71 Chevy C/10 lwb 350
5 speed nv3500
3.73 rear end
2.5" Front Drop and 4" in the back
Edelbrock perfomer rpm manifold
Edelbrock 600 cfm carb
Headmen headers
bad 71 chevy is offline   Reply With Quote
Old 07-23-2018, 02:03 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Fixing a lock
Does your key have a code number stamped on it? (Some do, some don't) If it does, I have a door lock you can have if you want to pay postage on it. If the key doesn't have a code number on it you would have to send me a key so I can key my door lock like your other locks.....
LockDoc
Leon
Old 07-23-2018, 05:27 PM   #3
bill3rail
bill3rail's Avatar
Re: Fixing a lock
I was going to say wait for LockDoc...But his strike was faster than mine!
LockDoc may have a complete new set to replace all three with a new key, which I think is a good idea to eliminate the possibility of spare keys being around town. Plus with a complete new set there will be no wear in the cylinders and on keys.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-23-2018, 05:35 PM   #4
Getter-Done
Getter-Done's Avatar
Re: Fixing a lock
I was going to say Same as above talk to LockDoc
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 07-23-2018, 08:46 PM   #5
bad 71 chevy
Re: Fixing a lock
I will have to check the factory key later this week I will pm you doc thanks
5 speed nv3500
3.73 rear end
Headmen headers
Old 07-23-2018, 10:31 PM   #6
LockDoc
LockDoc's Avatar
Re: Fixing a lock
Sounds good.
LockDoc
Leon
Old 08-03-2018, 02:54 PM   #7
Colfax
Re: Fixing a lock
I had to replace both door locks on my 1970 C10 yesterday.(some a$$ h%%%) stole my keys. Biggest problem was getting the door panel off. I bought new locks from A Z for $17. It took about 30 minutes per door. Not a difficult job. Note how the old lock sets in before taking it out. You will need a part from the old lock to place on the new lock.
Colfax is offline   Reply With Quote
Old 08-03-2018, 03:08 PM   #8
bad 71 chevy
Re: Fixing a lock
I haven't had a chance to deal with it have 2 used locks with key that I picked up from a friend just need to sit Down and figure it all out
5 speed nv3500
3.73 rear end
Headmen headers
Old 08-03-2018, 03:19 PM   #9
Colfax
Re: Fixing a lock
While you have the door panels off it would be a good time to put sound deadner inside the doors.
Old 08-03-2018, 03:27 PM   #10
LockDoc
LockDoc's Avatar
Re: Fixing a lock
And lube all of the window rollers, tracks, door latches and remotes. Basically anything in there that moves....
LockDoc
Leon
Old 08-03-2018, 03:35 PM   #11
Colfax
Re: Fixing a lock
Would you recommend white lithium for lube?
Old 08-03-2018, 04:00 PM   #12
LockDoc
LockDoc's Avatar
Re: Fixing a lock
No I don't. White lithium gets as hard as a rock after a while. I just use a good penetrating oil with Teflon in it. I have used general purpose grease but it attracts a lot of dirt and grime.....
LockDoc
Leon
Old 08-03-2018, 06:10 PM   #13
michael bustamante
michael bustamante's Avatar
Re: Fixing a lock
i second the spay lube with teflon
1967custom
michael bustamante is offline   Reply With Quote
