Old 07-25-2018, 07:52 PM   #1
dmjlambert
dmjlambert's Avatar
Parallel Flow Condenser
Here are my facts:
R12 is $25 to $35 per can on craigslist when it is available. By the time I drive across the county for an average pick up of a can of it, consider the total cost to be $40.
Here is my question:
Is there a certain price point at which using R134A is better? Or is R12 worth buying even if it goes to $50 per can? Is the case of 12 cans I see listed right now for $300 something you guys would recommend I run over and get right now?
Rambling:
I would like to have an A/C that works fine when it is 110 degrees outside and high humidity. In my 1969 CST/10 have a stock 350 engine with A/C cab and original A/C in poor condition, so I would like to refresh the system. I have a stock clutch fan. Engine cooling performs fine under all conditions, stop and go traffic, hot outside, or whatever.
From what I have seen on the web including this site, my research tells me using a parallel flow condenser is of upmost importance if using R134A. My wife's modern car uses R134A and the A/C blows so cold even if it is hotter than hell outside, I can't run it on the max cold position without wearing a jacket or rolling down a window. So I would like to think that is achievable in my truck. I'm thinking the thing that would prevent me from achieving that is a regular condenser. I don't want to end up with crappy air since I'm getting ready to spend big bucks on this.
More questions:
Does anybody know of year/make/model of car or truck for which a brand new condenser can be ordered from a parts store, and which is parallel flow and which will fit in our trucks? And the maker of any adapter tubes with fittings that will adapt, perhaps fabricator who is familiar with these trucks and what it takes to get superior A/C working?
Does anybody know if Vintage Air or Old Air or any of those full kit makers actually has a parallel flow condenser as part of their kit?
Old 07-25-2018, 10:12 PM   #2
68c10airstream
68c10airstream's Avatar
Re: Parallel Flow Condenser
I will sometime get around to finishing my ls 5.3 ac system. It will be basically a trailblazer ss 6.0 ls compressor/lines/condenser and make it adapt to a stock ac box. The condenser in my hands fits nicely in the opening. You would need to adapt/tig weld the ends to match what you have. I figured that the trailblazer interior volume was more than our truck cab so it should be ok. I'm using the stock 5.3 clutch fan and a 68 fan shroud.
Why use a trailblazer compressor? Because the suction/discharge ports on the compressor are positioned front to back and i won't need to notch my frame for the lines.
With your system switched to r134 your poa valve i believe will need to be adjusted/replaced to work right, but someone will chime in that has been there and done it, or search for r134 poa valve articles. Good luck!!
68c10airstream is offline   Reply With Quote
Old 07-25-2018, 10:20 PM   #3
lutronjim
There is a refrigerant that is called FR12 that works in a R12 system that's much cheaper
lutronjim is offline   Reply With Quote
Old 07-25-2018, 10:36 PM   #4
Greasey Harley
Greasey Harley's Avatar
Don't know about retrofit but, an original r12 system in good working order should be plenty cool in a regular cab truck. Our C30 shop truck will just about grow icicles if you let it run long enough.
We replaced the o-rings and soft lines with repops from lmc, poured some oil in it, e-vacc-ed the system down to 300 microns and put the recommended charge ( 2.75 lbs I think) back into the system. It blows COLD.
It is crucial that you pull vacuum on the system before you charge it.
You might reach out to your local hvac guy and see if you can get him to top you off with "Hot-shot" , that stuff works great in R12 systems.
Greasey Harley is offline   Reply With Quote
Old 07-26-2018, 08:08 AM   #5
brown7373
brown7373's Avatar
I spoke with Classic Auto Air last week, and they do not sell a parallel flow condenser for our trucks...although there is talk about making one. If anyone knows if someone else makes them, I'd be all ears. I have one in a 72 Cutlass Convertible and a 70 Bonneville Convertible and both blow 30 degree from the vents, using 134a,with real recalibrated POA and all other components in good working order. Using and recalibrating a POA in my 72 truck helped a lot, but not as good as the cars with parallel flow.
brown7373 is offline   Reply With Quote
Old 07-26-2018, 10:07 AM   #6
bMr
Originally Posted by dmjlambert View Post
Here are my facts:
Rambling:
More questions:
After similar deliberations for many months I'm in the middle of the swap to R134. I didn't want to spend a lot of money buying R12 only for it to escape to the atmosphere should there be a leak. And seeing as the front seal of the compressor is a known weak point, if I was going to be in for a compressor I might as well make the swap while I'm at it.
There are several great threads on here about the 134 swap, condensers, POA valve adjustment, etc.; many of those threads benefit from the input of board member FAA Benny.
For me the biggest decision wasn't whether to swap from R12 but whether to switch to a new system from Old Air, Vintage Air or the like. I did not want to spend the $500+ buying hoses, a compressor, a condenser, and misc parts and refrigerant and still be be hampered by 45+ year old diverter flaps, cranky vacuum actuators, and the like. Had my diverter box or control head needed replacing or refurbishing, I probably would've swapped to a new system.
To your point about the condenser, as of July 2018 no one sells a bolt-in parallel flow condenser to work with the factory hard line locations. However, there are a plethora of modestly priced parallel flow condensers available on eBay or through other vendors, and Vintage Air manufactures hard lines with the requisite o-ring connections in various lengths that you can then bend yourself. (Local parts stores rent tubing benders.)
For sizing a new condenser, the space available is about 31"w by 15"t. There are two stampings on the radiator/header panel which limit width, and the hood latch assembly is the limiting factor on height.
bMr is offline   Reply With Quote
Old 07-26-2018, 10:23 AM   #7
A1971Blazer
A1971Blazer's Avatar
I'm in the middle of this same project right now....My '72 K/5 is missing some pieces and I sourced an entire under hood unit for $100.00....
The PO had completely reconditioned the entire under dash assembly already so it's ready to go.......
It's funny about the price.....I had one old can of r12 in my cabinet....price tag still on it.....97¢....
I found 4 cans locally for $20.00 and 4 cans that I had shipped to me for $20.00+ shipping...
I'm planning on trying to get it working with the r12 charge....stay tuned...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 07-26-2018, 10:25 AM   #8
72c20customcamper
72c20customcamper's Avatar
I have 2 20lb tanks of r12. I bought it cheap from the supply house just before they banned the sale of it. 3 of my cars use it. But so far none of them leak as of now.
Old 07-26-2018, 10:27 AM   #9
demian5
demian5's Avatar
There is one through Classic through Original Air...
https://originalair.com/67-72-chevro...t-134a-stage-2
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 07-26-2018, 10:42 AM   #10
davepl
davepl's Avatar
I have a parallel flow condenser. New lines. But the old compressor leaked, so new aluminum compressor painted black to look stock, and it blows cold and works great and has lasted for years with R134
Overheats in traffic with the AC on, that's how well it works :-)
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-26-2018, 10:45 AM   #11
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Parallel Flow Condenser
Ok all this talk about R-12 and 134 A is like Chevy vs Ford. Both do the job well. Both have the same things bad about them but if both systems are working right they will blow 30* air at the vents.
My 71 C 10 has had mods done by me and it blows 30* no matter what and it's been in operation for years. Yes it has the factory basic system inside the cab but the out side is all newer stuff.
I went with Classic air stuff along with late model Chevy truck stuff and the hose connections are like anything else just buy what you need. I bought Classic air kit with all the fittings, compressor, condenser and put it all together had the lines made up and it works great.
These are the old 305 TPI setup.
The 6.0 with same setup.
In my 64 SS Impala I used everything in the car when I bought it which per the owner at the time had been swapped out. I put new lines and drier in it with 134a and it blows 32* all day long. I'm running the older A-6 compressor in the car also. See how the lines are curled up. I took it all a part and had longer lines made and hid them inside the fender to clean that side up.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-26-2018, 11:28 AM   #12
leddzepp
Moderator
leddzepp's Avatar
It’s simple: Use whatever gas the system components are designed for. Mixing and matching components to save a few bucks to run r134 will just lead to headaches frustration and a poorly functioning AC. Both of my factory AC systems run r12, blow snowballs in 110 degree heat and have worked for years with no issues. Prior to that I chased my tail trying r134 in it. All my newer vehicles run r134 and blow snow too...because that’s what they are designed for.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-26-2018, 04:50 PM   #13
Big Kev-O
Big Kev-O's Avatar
"they will blow 30* air at the vents"
For the record your cars AC should blow air around 40-42 degrees. IF your vents are putting out 30* air your refrigerant charge is not correct, or you have a broken thermometer. When an AC evaporator is under 32* it begins to freeze the moisture in the air and turn your evaporator into a huge ice block which prevents air from flowing across the coil. You also risk slugging the compressor with liquid.
You should not try and attempt to charge your system to achieve 30* air out of the vents.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 07-26-2018, 07:26 PM   #14
Rufas
Rufas's Avatar
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 07-26-2018, 07:51 PM   #15
dmjlambert
dmjlambert's Avatar
Thanks everybody for input so far.
OK, if I want to get going like that, what parallel flow condenser do I buy? What do you mean about overheats in traffic, do you mean your engine overheats and you think it is related to your AC?
Any experience with that kit? I probably can't use it anyway because I don't have a long water pump.
Originally Posted by Andy4639 View Post
...and put it all together had the lines made up and it works great.
What sort of place do you go to have the lines made up?
... When an AC evaporator is under 32* it begins to freeze the moisture in the air and turn your evaporator into a huge ice block which prevents air from flowing across the coil. You also risk slugging the compressor with liquid.
Yes, I guess I should have said I would like the A/C to work for long trips as well, not just for show or short trips.
This is interesting info. I don't have actuators and flaps that work properly, but I have not sufficiently explored them to see if I can fix. I don't know how to pick among the condensers from eBay or other sites, and make sure I end up with something I can use. Getting the Vintage Air hard lines in a length I like and with the fittings I need and bending to shape sounds interesting. I have a tubing bender. The thing that would worry me is figuring out what that connector name and size is that is on the truck and that is on the condenser that arrives, and figure out if it is metric or standard, and any other decisions I would need to make to keep from ordering something that just doesn't work out.
For the R12 crowd who have massive quantities stockpiled:
I imagine by the time I replace a part or two, test the system, and then charge it up with a couple hundred dollars worth of R12, it would make me feel pretty bad to watch and hear that spring a leak a year later and spew money into the air, then repeat when the R12 is $400. I have a 49 year old system here and if I'm going to replace every part to increase the chances of me going for several years without failure and re-purchase of R12, I might as well not buy an all-new R12 system. By the way, I have also noticed old R12 cans I usually see are only 1/2 full after so many years of laying around and getting rusty. These are the things that make it a difficult decision. For those of you who have stockpiled since you were young and have no worries about future cost, that's great.
Old 07-26-2018, 09:39 PM   #16
Andy4639
Old member
Andy4639's Avatar
Red face Re: Parallel Flow Condenser
Sorry yes 42* I was at work and didn't have time to go back and check my spelling, sorry 40* is correct on both vehicles.
Old 07-27-2018, 09:34 AM   #17
bMr
The proverbial slippery slope! LOL, been there and done that.
If it were me, I'd put together a rough estimate of replacing/repairing the in-cab components and then an estimate of each option: recharging R12, swapping underhood components to R134, and buying a complete kit to replace underhood and in-cab components. At least then you'll know how much you're likely to be in for.
Old 07-27-2018, 09:47 AM   #18
1972RedNeck
1972RedNeck's Avatar
Duracool, or a homemade copy of it will cool as good as R12, and better than R134. It is a mix of propane and isobutane. Flash point is actually higher than r134A.
Best part is that you can mix your own. One 8 oz can of isobutane (mountain stove fuel), and 12 oz of Coleman propane (found to be drier than most). Takes about half the weight as the freon charge.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-04-2018, 04:42 PM   #19
dmjlambert
dmjlambert's Avatar
After reading more, I am even more lost. I am frustrated because I have no place to walk into an look at the parts or a complete system, and I'm a visual learner. Let's just say I'm taking my truck and tools and moving to a desert island. I will have no chance of ordering any parts after I get there. So unless I can fabricate parts out of coconuts I need to order all I need now. Let's say my truck has been stripped of the A/C related stuff, condenser, compressor, hoses, evaporator and evaporator box, heater core and box, blower motor and fan, all inside ducts and diverters, outlets and outlet hoses, vacuum-operated flaps, control panel, and whatever else is part of the A/C system in the cab and in the engine compartment.
If I order an Old Air system or Vintage Air, or whatever kit I should get to install a R134a system, what do I need in addition to that kit? I have a 350 engine with short water pump and v-belt drive system and the holes in the cab firewall and dash are for a factory A/C equipped truck.
Old 08-04-2018, 05:28 PM   #20
dmjlambert
dmjlambert's Avatar
Here's a kit, I have no idea what brand. I suppose I am concerned about getting replacement parts in case any part of it breaks. It is possible to tell from this picture if this is a parallel flow condenser? The description is not detailed.
http://www.classictruck.com/product/...roster_HAC-236
Old 08-04-2018, 06:20 PM   #21
dmjlambert
dmjlambert's Avatar
Here's the condenser Classic Industries sells. In their paper catalog, which I received today, it says 1967-72 "all refrigerants." But I don't know if it is parallel flow.
https://www.classicindustries.com/pr...s/ap72011.html
Old 08-04-2018, 07:00 PM   #22
RichardJ
NO.
The first thing you will notice about a parallel flow is the large round tanks on both ends. The second is that the horizontal tubes are flat instead of the old style round tubes. The side tanks are chambered so that the refrigerant flows horizontally in 3 or 4 lines, then drops down and flows back in the next group of lines.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 08-04-2018, 07:27 PM   #23
RichardJ
I couldn't find what you are looking for on the Vintage Air web site, but found this on Jegs.
Note that it says it is a representative image. The price includes dryer and other hardware.
Call Vintage Air and be clear about what you are looking for. Their image appears to show a parallel flow.
Old 08-04-2018, 08:14 PM   #24
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
My '78 was converted to R134A by the previous owner in 2007. It still has the original condenser, evaporator, and new compressor and receiver. On the highway I have to turn the fan down because it will get so cold on high. In city driving, it is not as cold, but I never need to roll the windows down or break into a sweat.
I think the only difference between this setup and the 67-72 is the metering device method and there is no low-side thermostat cycling switch.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 08-04-2018, 09:41 PM   #25
dmjlambert
dmjlambert's Avatar
Originally Posted by RichardJ View Post
NO.
Thanks for that picture and description, that helps. The picture of the condenser with A and B dimensions is interesting. Is it from a vendor who will sell me a condenser if I just specify the A and B dimensions? If so, perhaps brackets that I would need to fit the truck could be added or clamps fabricated.
Regarding the Jegs listing for the Vintage Air condenser, is -6AN and -8AN fittings what connects to the existing factory setup, or would I need to get some sort of adapters or tubes made? That looks like a good find, I will give them a call at Vintage Air and ask more about it.
a/c, condenser, parallel flow condenser, r134a
