Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-11-2017, 12:27 PM   #351
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Ok Boys and Girls it's Storytime
Regan,
Here is a link for a fix for Firefox that I saw on another thread. If I find one for Chrome I will post it here too. Its just a plugin to "fix" you browser to display the pictures. You should be able to find on for Chrome by doing a search for something like "photobucket fix for image links"...
Depending on your browser you can get a plugin that fixes the photobucket links. this one works for firefox
https://addons.mozilla.org/en-US/fir...otobucket-fix/
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-11-2017, 12:29 PM   #352
aggie91
aggie91's Avatar
Here is the fix for Chrome. It is just a link to add a plugin patch so that Chrome will display the photobucket images from the existing links:
If your running Google Chrome click the link and install the patch and it will fix the Photobucket problem
https://chrome.google.com/webstore/d...alioapbifiaedg
Karl
The LST Challenge:
Old 12-12-2017, 09:16 AM   #353
regan wilson
regan wilson's Avatar
Thanks Capt and Aggie. I followed the link to the Chrome webstore. I typed photobucket and it came up with three options. I clicked the first one that said Photobucket Embedded Image Fix. It worked ! I guess I can keep this thread going. I just got through going through my whole thread. It reminded me of how crazy I am. lol I guess I can use Imagur or something else. What are yall using to host pics with?
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 12-15-2017, 08:51 AM   #354
hotrod 80
mini truck racer
hotrod 80's Avatar
I gave up . Im no computer guy for sure.
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-18-2018, 10:08 AM   #355
regan wilson
Well I figured give an update. Photobucket freed all the pics. I went ahead and paid the smaller fee they came up with. So I'll start posting some new pics. We put the 672 9* single four combo on the dyno. The results were not as expected. We tore the top end off of it. The heads are at Slick Ricks and Hogans is on hold for a new Sheetmetal Intake. Then Ill pull the two Dominators off the shelf and try again. On another note my Dry Sump was a fun new toy to play with. I'll post back soon.
Old 07-19-2018, 09:14 AM   #356
aggie91
aggie91's Avatar
Sorry to hear you are having issues making the power you want. Hope this next round works out.
Karl
The LST Challenge:
Old 07-25-2018, 07:14 PM   #357
regan wilson
The drip rail was getting pretty bad. The seam sealer was cracked up and holding moister underneath.
Old 07-26-2018, 06:36 AM   #358
regan wilson
[IMG][/IMG]
Ok now you can see the damage from the cracked seamsealer. It was holding moisture causing this mess.
Old 07-26-2018, 06:49 AM   #359
regan wilson
[IMG][/IMG]
This is mocking up the dry sump lines. I got my lengths figured with rubber hose. Then sent them off. They came back braided stainless ptfe hose.
Old 07-26-2018, 06:53 AM   #360
regan wilson
[IMG][/IMG]
Freshly painted core support with my new dry sump tank mounted.
Old 07-26-2018, 06:58 AM   #361
regan wilson
[IMG][/IMG]
Pic of the motor before we got the oil system on it. Those heads are layed over so far at 9 degrees. It makes it look huge.
Old 07-26-2018, 07:00 AM   #362
regan wilson
[IMG][/IMG]
All hooked up on the dyno.
Old 07-26-2018, 07:04 AM   #363
regan wilson
[IMG][/IMG]
Firewall after a good massaging for clearance. Fresh paint and some added touches around the bars. I used to use seamsealer around the bars but it would crack and come out.
Old 07-26-2018, 07:10 AM   #364
regan wilson
[IMG] [/IMG]
Top all fixed. Its dirty in this pic but fixed. If I hadn't fixed it. In another year or two it would have been too late.
Old 07-26-2018, 11:29 AM   #365
aggie91
aggie91's Avatar
Nice updates. Good thing you fixed that drip rail issue now.
Karl
The LST Challenge:
Old 08-09-2018, 09:12 AM   #366
regan wilson
[IMG][/IMG]
Have you ever seen a set of heads in a sexy pose?
Old 08-09-2018, 09:15 AM   #367
regan wilson
[IMG][/IMG]
Thanks Slick Rick
Old 08-09-2018, 09:18 AM   #368
regan wilson
[IMG][/IMG]
Doesn't look like a 16 to 1 Piston does it?
Old 08-10-2018, 09:07 AM   #369
aggie91
aggie91's Avatar
No it really does not look like it would go that high. But a very small camber on such a big bore, it don't take much, but it looks like a dish, how big is the dish in the piston top?
Karl
The LST Challenge:
Old 08-10-2018, 09:13 AM   #370
regan wilson
I cant remember the dish ( or inverted dome lol ). The heads are now 62cc's
Old 08-30-2018, 01:54 AM   #371
djracer
djracer's Avatar
Good to see you are still at it. I so got to get back to work on mine!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-19-2018, 05:42 AM   #372
D13
D13's Avatar
Kind of freaked me out when I saw the sump picture, thought it was an L6 wiht huge plug wires.
Is that rust I see in the bores on post 368?
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-19-2018, 02:23 PM   #373
regan wilson
Nothing to worry about. We were running it on Q16. It is an oxygenated fuel. Thats why the piston looks a little crusty too.
Old 11-20-2018, 11:40 AM   #374
regan wilson
[IMG][/IMG]
Old 11-20-2018, 11:40 AM   #375
regan wilson
[IMG][/IMG]
