Old 07-29-2018, 05:35 PM   #1
DaHos
DaHos's Avatar
4L60e and backup lights
Floor shift, nss is on side of shifter.
Lokar bl1400 will not work due to oe range box.
So what i need to know is how do i use the 4l60e backup signal, i have the later 4 pin and 7 pin connector at trans and I have the 2 green wires from oe column mounted nss switch...Dk green has 12v when key on......
And this is where I'm stumped......
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 07-29-2018, 06:25 PM   #2
DaHos
DaHos's Avatar
Re: 4L60e and backup lights
This is all i got (disregard the white jumper wire)
1967 C10 SWB
Old 07-29-2018, 06:34 PM   #3
Bigdav160
Bigdav160's Avatar
When it is jumpered (key on) are the BU lamps on? AFAIK, they should be. The dark green would be the same as the pink on the diagram and the light green from the switch goes to the lt green in your jumpered connector.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-30-2018, 08:50 AM   #4
DaHos
DaHos's Avatar
Yes BU lights worked prior the swap and still do when jumped......Just cant use the column mounted switch.
So would it be safe to say the power "pink" wire is feeding +12v to switch so the dark green would not be needed?
Just attach light green to light green?
1967 C10 SWB
Old 07-30-2018, 09:25 AM   #5
ls1nova71
ls1nova71's Avatar
Light green to light green (pin F) and dark green to pink (pin C). You most likely don't have that pink hooked up to anything since it's not needed in a stand alone engine rewire.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-31-2018, 06:06 PM   #6
DaHos
DaHos's Avatar
well......pink has power from fuse panel, I hooked the Lt green from oe harness to Lt green pin F, turned key to on position and placed in rev, Lights came on.........but when I start the truck and put it in rev it kills the motor......ugh.....???? any ideas?
1967 C10 SWB
