![]() Join Date: Sep 2007
Radio harness question
Ok so i pulled a radio out of a 67. (Found out later i cant change radio statiom. Boo)
But i also found my first uncut radio harness. So is the 67 harness different? Theres 2 plugs on the harness that i havent figured out. First pic shows that plug sticking up in the air. It has the brown live and the red pos. Sticking in It. Second the accessory plug sticking out of the plug that goes into the fusebox. Any ideas?
1967custom |
![]() Join Date: May 2010
Re: Radio harness question
Here's a picture on what I've seen for a radio harness. The green and black (brown? Can't tell in my picture) wires go to the speaker. Your positive lead appears to have a connector to run some other accessory. If I recall correctly, there is a connector like this on my red ignition unfused wire.
yeah that's like the one I pulled from a 69 c20. this 67 harness positive lead looks different for some reason. and my positive starts off brown and a thinner gauge
1967custom |
Old member
The leads just have the piggy backs on them for other accessories.
It just depends on what was ordered on the truck are added. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#5 | |
The Older Generation
LockDoc
Cool man thank you!
1967custom |
