![]() Join Date: Jul 2009
'77 on a '71 frame, or some sort of homogenization??
Okay,
I just bought my '77 2wd swb C10 this past weekend and drove it home from Chattanooga and it did fine. The suspension is a bit sketchy as it has cut front springs with spring spacers twisted into them and the rear only has 3 leafs remaining, so its a bit "loosie goosie" to drive. Now...I have a '71 swb C10 frame here at the house, along with complete Porterbuilt front mild DropMember and a complete rear touring DropMember that I was going to put under my '68. But I'm a squarebody guy that tried to go '68. It just didn't happen, so I want to try and build this '77 with the PB stuff I already have. I know all the rear of the '77 vs the '68 frames are COMPLETELY different after about a foot past the trans crossmember, so that would have to be 'retrofitted'. But with a touring DropMember, the bed floor would have to be modded anyway, so that doesn't seem like a major hurdle. And I know the 67-72 and the '73 up K-members interchange as I have done it on a '70 GMC, so the front DM should work either on the current '77 frame, but what about the '71 frame under the '77? Feasible? Without crazy modifications, will this work? Has anybody done this? And, I did search prior to posting and never found a definitive answer either way. Last edited by nlped; 08-02-2018 at 11:06 AM. |
![]() Join Date: Jun 2017
Re: '77 on a '71 frame, or some sort of homogenization??
I'd sell what you have and find another used setup to put on your frame. IMO.
On the front- aren't the 4 holes different on the sides of the frame?
1949 Chevy 3100 P/U http://67-72chevytrucks.com/vboard/s...d.php?t=302780 1976 GMC Sierra Classic C35 CCSB http://67-72chevytrucks.com/vboard/s...25#post8188825 |
67-72 parts collector,…
![]() Join Date: Nov 2002
I believe the front dropmembers are slightly different in the frame height.
Meaning the 73-87 frames are a little taller. Which doesn’t really matter except where the PB piece goes inside the front frame rails.
I would buy some new springs for the 77 and enjoy it as is.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
All my PB stuff is new... one more reason I’d like to use it.
Thanks Keith, that’s good info. I’m leaning more & more towards “fitting” the ‘71 frame under the ‘77.
Seems to easy.
