Old 08-03-2018, 10:05 AM   #1
v30crewcab
v30crewcab's Avatar
5.3 with 90's 4l60-e?
Is it possible for a ls computer to control a mid 90's 4l60e trans? I am looking at swapping a 5.3 into a 76 pathfinder 4x4 van, and it uses a th350 2wd with a special long adapter to a Ford 205 trans. I know I can just use a regular 700r4, but figured the trans might work better if the computer controls it. But I need to have the 4bolt tailshaft like the older ones use. I have no problem building a custom trans if I can use the newer electronics in the older case. just thought I'd see if anyone else had run into this.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 08-03-2018, 11:44 AM   #2
SlowGreen71
Re: 5.3 with 90's 4l60-e?
I'm not sure about the bolt pattern to a 203. But the easiest way I've put a 4l60e to a 205 was a 6 to 4 bolt adapter and a spacer. Both from advanced adapters. No tearing the trans down to change shafts etc. here's a link.
http://67-72chevytrucks.com/vboard/s...d.php?t=754191
Another showing a little more detail of how it goes together.
http://67-72chevytrucks.com/vboard/s...d.php?t=754661
SlowGreen71 is offline   Reply With Quote
Old 08-03-2018, 05:15 PM   #3
v30crewcab
v30crewcab's Avatar
I edited my post. its for a 205. its a special adapter made by pathfinder that I will reuse. The question is wether an ls computer will talk to a 90's 4l60 or will I have to run a 700r for overdrive.
71 longbed 5.3 4l80
Old 08-05-2018, 03:12 AM   #4
87Skier
87Skier's Avatar
There's no reason that it can't. There are few issues, some I sure you know about.
First, the input shafts are different, so you need an adapter to run a non-LS transmission with an LS engine:
crank spacer 12563532
6 longer bolts 19257940
flexplate 19260102
Second, in ~95 GM started doing PWM torque converter control. You should use one of these rather than 92-94 trans.
Third, 06+ use an additional sensor, so the wiring is different. If you have a gen IV motor, the ECM/TCM would probably have to be tuned
Be sure to check the harness and transmission pin wiring.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 08-05-2018, 05:50 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'll toss in that fwiw, just make sure its actually a 4l60e there were those sneaky few situations when it was just a 4l60 which would be the same TV cable situation that the 700r4 uses.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-05-2018, 09:03 PM   #6
v30crewcab
v30crewcab's Avatar
cool deal. does anyone know what year they changed from the 4bolt tailhousing to the bigger 6 bolt one?
71 longbed 5.3 4l80
Old 08-07-2018, 01:37 PM   #7
87Skier
87Skier's Avatar
Pretty sure it was 99.
Old 08-08-2018, 02:27 PM   #8
93Polo
flexplate 19260102
Looks like the flexplate in my 01 6.0 2500HD. They are known to crack. I replaced mine with a unit from Circle D which has worked great.
93Polo is offline   Reply With Quote
Old 08-12-2018, 01:33 PM   #9
LH Lead-Foot
The 5.3L Vortec truck engine uses an off-set flex plate that with a little filing inward will match torque convertor pattern. The hub center for eBay for $25 to center crank to convertor nose. That was all it took for mine.
Removed
LH Lead-Foot is offline   Reply With Quote
