Old 08-08-2018, 10:19 AM   #1
Grumpy old man
Grumpy old man's Avatar
rear coil spring removal - easy
I see a lot of guys wrestling with rear upper coil spring bolt removal so here is the easy way ,Takes less than 5 minutes .
Use an air cut off wheel / cold chisel / BFH
reach inside the frame rail with your cut off wheel ,
You can see the bolt by looking thru the frame rail opening here marked by blue arrow.
Cut down one side of the nut seen thru the frame .
using cold chisel placed on either side of the now cut nut use the BFH a couple times and the nut will fall off allowing the bolt and spring keeper to drop . works on both sides , Easy Peasy .
Old 08-08-2018, 02:22 PM   #2
saxart
saxart's Avatar
Re: rear coil spring removal - easy
Grumpy-
This is fantastic info. Thanks for taking the time to post this up!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 08-08-2018, 03:09 PM   #3
54Caddy
GM Addicted
54Caddy's Avatar
The way I do it is take off shocks, panhard bar, remove bracket for brake hose off differential. Then remove lower retainer off coil and drop the diff down. Use impact and extension and easily gets to upper bolt. Wrench to hold nut and done deal.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 08-08-2018, 08:18 PM   #4
firedemon
I use a torch takes longer to unwind the hose than to cut
firedemon is offline   Reply With Quote
