Old 08-08-2018, 11:15 AM   #1
NeoJuice
Help Finding a lower rad hose
Water pump is 1 3/4" and lower rad neck is 1 1/2" and the elbow is probably just a standard 90 degree. Anyone have any part numbers?
Please and thank you.
NeoJuice is offline   Reply With Quote
Old 08-08-2018, 06:49 PM   #2
crossfire84
crossfire84's Avatar
Re: Help Finding a lower rad hose
Go to your local auto parts store and have them look up the sizes in there books.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 08-08-2018, 07:07 PM   #3
my56chevytruck
my56chevytruck's Avatar
sorry, no part numbers, BUT, I'd suggest you mock up a hose using hand towel tubes or go buy some flexible tubing and make the shape you need. you should be able to find a hose with 2 different size inlets
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 08-08-2018, 08:04 PM   #4
joedoh
joedoh's Avatar
what motor what rad what truck?
and if its an AD with a SBC and a stock style rad look here.
http://67-72chevytrucks.com/vboard/s...d.php?t=768479
Old 08-08-2018, 08:30 PM   #5
3757chevy
3757chevy's Avatar
Napa 7344 or 7648 depending on where you need the length of the long side. or you can use an 1-3/4" hose with a reducer to 1-1/2" #901
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 08-09-2018, 02:45 PM   #6
Backroads67
Active Member
Gates has a reference guide, (pdf) chart of molded hoses online. Download it and it has inlet and outlet sizes and length. When I did my chevelle, I found a half dozen that might be close then went to the parts store had them look up or cross reference the number, which had a pic attached so I could see what would work.
72 K10 swb in progress
67 C10 swb
66 chevelle SS Conv
40 Plymouth pickup
Backroads67 is offline   Reply With Quote
Old 08-09-2018, 04:05 PM   #7
NeoJuice
Sorry I forgot to mention the engine type. SBC350 with AD OEM style aluminum rad.
I will look at the napa part numbers. Thank you to everyone for the great information.
Old 08-09-2018, 08:16 PM   #8
OrrieG
OrrieG's Avatar
look at this http://67-72chevytrucks.com/vboard/s...d.php?t=509289
Old 08-23-2018, 10:58 AM   #9
NeoJuice
I want to say thanks to the people who responded to my post. I first tried the Napa 7648 but the 1.75" neck was to long off the water pump. Then I tried the 7344 and it was just right. Just had to trim a couple inches off the 1.5" end and it fits perfect.
Old 08-23-2018, 02:50 PM   #10
dsraven
that's great.
for others who just can't find a match, I suggest using a piece of muffler pipe or the like, bent to fit the area, then have the exhaust shop swage one end a bit bigger to fit the larger size hose. install with short pieces of hose at each end. the bonus is that the pipe can have a tab welded on if it is a long run and then it can be supported-flexibly of course to allow engine movement under torque up. smooth the cut ends and use good quality hose clamps. it's only gotta hold 16 psi.
dsraven is online now   Reply With Quote
Old 08-23-2018, 03:08 PM   #11
mr48chev
mr48chev's Avatar
We need to put that hose number down in the things to remember list because someone else will be looking for it before long.
My ongoing truck projects:
Old 08-23-2018, 03:59 PM   #12
MiraclePieCo
MiraclePieCo's Avatar
That's weird; all the OEM style aftermarket aluminum radiators I've seen have had 1-3/4" bottom hose size. I didn't even know they were available with 1-1/2 lower outlet. Mine:
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 08-23-2018, 06:07 PM   #13
NeoJuice
I thought it was a OEM style rad. I'm not sure because I bought the project partially completed.
Here is another picture for reference. I assumed it was OEM style because it fits between the rad support and blots into the factory OEM mounting holes. It also has built in trans cooler line hookups on the bottom.
It also has a flex-a-lite syclone fan on the front and I've added a painless wiring fan relay as well.
