Old 08-11-2018, 05:46 PM   #1
NC_John
NC_John's Avatar
Speedo calibration - Dakota Digital HDX/ HP Tuners
Went for my first test drive yesterday and my hdx speedo was reading extremely low (didn't read over 20-25 mph, even at a cell phone gps indicated 55-60). I tried to do the adjust procedure in the gauges but was only allowed a max of 125% which was nowhere close to where I need to be.
I am figuring I need to make a change in the pcm through HP Tuners. I've got a t56 with a 4.56 rear (which is likely the cause of the speedo reading so low). My concern is I've read online that making too large a change in the pcm will brick it. Is this still an issue? What can I do to avoid messing it up? Anybody know? I'll have an opportunity to get into the pcm when it goes on the chassis dyno and make any changes but I need to get it right the first time since I personally don't have my own copy of the software.
Thanks!
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 08-12-2018, 08:56 PM   #2
Wildkarde
Re: Speedo calibration - Dakota Digital HDX/ HP Tuners
All of the VDX/HDX units I have seen calibrate the speedo by putting the system into calibration mode, press button, drive 1 measured mile, press the button again.
how dies yours calibrate, and how do you have it hooked up?
Wildkarde is offline   Reply With Quote
Old 08-13-2018, 06:11 AM   #3
NC_John
NC_John's Avatar
Mine is getting all data through a bim module from the pcm. In this configuration all you can do for speedo calibration is adjust the incoming vss signal up or down 25%.
I know I can adjust the signal out of the pcm to the cluster through HP Tuners but am nervous because apparently its possible to piss off the pcm and brick it with too big of a change in these tables. Even HP Tuners acknowledged this in their forum but the posts were quite dated so I don't know if its still an issue.
1970 C-10 LWB "Blu"
Old 08-13-2018, 08:43 AM   #4
Hart_Rod
Hart_Rod's Avatar
I've never had a problem changing gear or tire size within the PCM. Not saying it can't happen, but never seen it.
Hart_Rod is offline   Reply With Quote
Old 08-13-2018, 09:58 AM   #5
Wildkarde
If you are getting the info through the BIM module then you need to calibrate the speedo through HP tuners.
If you are tuning yourself just go to go to Edit - Gear/Tire wizard - enter your tire size and gear ratio and hit the adjust button. 4.56 is well within acceptable parameters unless you are running some tiny wheel/tire combo.
Old 08-13-2018, 10:55 AM   #6
davepl
davepl's Avatar
Just a random helpful tidbit - I used to try to calibrate by driving by one of those radar speed signs, but besides being inconvenient it's not super accurate because they're at an angle.
If you've got an iPhone, there are a million GPS speedometer apps, and I imagine that feature is built into Maps as well. So you can check your speed pretty accurately that way wherever you've got a decent view of the sky.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-13-2018, 07:16 PM   #7
NC_John
NC_John's Avatar
Ok, thanks Rob.
1970 C-10 LWB "Blu"
Old 08-13-2018, 07:17 PM   #8
NC_John
NC_John's Avatar
Cool, thats what I will look for when we get set up.
I believe my rear tire is 28" tall so should be no issues there.
Thanks!
1970 C-10 LWB "Blu"
Old 08-13-2018, 07:20 PM   #9
NC_John
NC_John's Avatar
Yeah, I have a GPS driven speedo app on my phone. It was my only speedometer when I put the T56 in and my dash speedo no longer worked. It was also how I saw the current DD speedo is so far off.
Thanks Dave.
1970 C-10 LWB "Blu"
Old 08-13-2018, 10:57 PM   #10
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Off subject but how do you like the 456s with the T56. I’m running a 5.7 with T56 and 350 gears in. Ford 9”. Was thinking about going lower but like 373
Thanks. Hope you solve your problem
Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 08-14-2018, 05:00 AM   #11
NC_John
NC_John's Avatar
Steve
Hey Steve, the 4.56's are no problem with the six speed. I still use first gear and (at least with the previous engine) still don't see sixth gear until 80 mph. I bet you could even get away with 4.88's with this setup but you *might* turn first into a granny gear. Sixth has pretty much been a glamour gear for me. I am rarely on the interstate so have only gotten in it once or twice (and that was just to see how it felt). Looks great on the build sheet though
1970 C-10 LWB "Blu"
Old 08-23-2018, 08:51 PM   #12
NC_John
NC_John's Avatar
Follow-up - got the wheel diameter and gear ratio corrected in HP Tuners yesterday and speedo is now only off one or two mph off GPS. I can correct that through the gauge cluster.
Now to figure out why the cruise control doesn't work....
1970 C-10 LWB "Blu"
Old 08-23-2018, 09:09 PM   #13
Wildkarde
What year engine, and how do you have it hooked up, LED tail lights?
Old 08-23-2018, 11:41 PM   #14
solidaxel
solidaxel's Avatar
Well, that confirms the 6 speed for me........80+ !
3:73 and a TKO 600 and maybe 3% highway was the right decision 13 years ago
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-24-2018, 07:50 PM   #15
NC_John
NC_John's Avatar
I can use it a little sooner with all the torque of this new stroker. I think I got into it around 65 but it was borderline lugging the engine.
1970 C-10 LWB "Blu"
Old 08-24-2018, 07:55 PM   #16
NC_John
NC_John's Avatar
04, DBW, speartech standalone harness with cruise control added in (four or five wires from the harness IIRC). Dakota Digital cruise control stalk with all the relays inbetween the stalk and the harness to get the signals right. No LED lighting...
I just need to get under the dash and go over my wiring, maybe do some metering to see whats going on (or not going on). Got some other stuff thats higher priority. Heck, with the exhaust on it, I'm not super interested in any long rides down the interstate yet anyway. Its LOUD!!!!
1970 C-10 LWB "Blu"
