Old 08-12-2018, 06:44 PM   #1
RMBLFSH
What causes...
The back of the hood to lift, and how do I fix it?
RMBLFSH is offline   Reply With Quote
Old 08-12-2018, 07:08 PM   #2
saxart
saxart's Avatar
Re: What causes...
That is a classic sign of worn out hood hinges. You can either look for a tighter set of used hinges, or have those hinges repaired/rebuilt. This guy isn't cheap, but he does FANTASTIC work:
http://www.hoodhingerepair.com/
Willie did a set of hinges for my truck and I can't be more happy with them.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 08-12-2018, 07:45 PM   #3
mr.precision
mr.precision's Avatar
Re: What causes...
Yup the hinges are worn.
I have had some success by moving the hinge assembly UP which allows the hood to sit DOWN a little further..... depending on how worn the hinge rivets are. Just a suggestion.
mr.precision is offline   Reply With Quote
Old 08-12-2018, 08:22 PM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: What causes...
I concur, Willie at hoodhingerepair.com did my hinges and they are better than new.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-12-2018, 09:11 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Re: What causes...
What you need to do to lower the back the hood is to loosen the bolts that hold the hinge to the fender (only enough so that the hinges will move) and have a helper push up on the front of the hood while you tighten the bolts. This rotates the hinges back, raising the front of the hinge and lowering the rear. This will lower the hood in the back. Sometimes you can leave the front bolts snugged up and just loosen the rear two and get enough adjustment and sometimes you can't.. You need to be very careful when you close the hood after doing this in case you moved it too much or the hinges did not move evenly, side to side. Have your helper watch the rear and one side while you watch the front and the other side.
If the hinges are worn it generally won't change how high the hood sits by more than a fraction of an inch, unless they are about ready to fall apart. I have never seen a vehicle with this style hinge that you couldn't put the hood lower than the fenders if you wanted to. There is a lot of adjustment with these hinges. That is one of the things that makes it easy to align the panels.
If you put new rubber bumpers on the inside lip of the fenders where the hood closes, some of the replacement bumpers are a lot thicker than the originals and will hold the hood up, so check that also....
LockDoc
Leon
Old 08-12-2018, 10:37 PM   #6
darrellyates
Re: What causes...
Lots of these trucks exhibit this issue. Frequently caused by having the hood open to show off that engine...
I went thru a couple of sets on my last '68. For the current build, I just bit the bullet and bought a set of the polished aluminum ones by Eddie Motorsports. I've had the hood open and closed a lot, with no alignment issues so far.
I believe that was the best solution for my truck anyway.
Good Luck! I've got a set of original hinges I wish somebody wanted... NOT for sale, just wish I knew somebody who wanted them.
darrellyates is offline   Reply With Quote
Old 08-12-2018, 11:33 PM   #7
67swb72klb
67swb72klb's Avatar
Re: What causes...
If you haven't done it lube the complete hinge helps a bunch if its dry.
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 08-13-2018, 01:03 AM   #8
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: What causes...
This. Ready to mount and powder coated too. He treated me well and nice guy. I'm a year out from mounting those and the door hinges he rebuilt.
Speak of Willie, he suggests Sea Foam DC-14 Deep Creep Lubricant.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-13-2018, 02:26 AM   #9
Fbks_Cruiser
Fbks_Cruiser's Avatar
Re: What causes...
LockDoc
This! My hood looked just like yours. Thought I needed new hinges. Did a bit of searching on the forum and found exactly what LockDoc is suggesting. I tried it and my hood now fits perfectly and “pops” when I release the latch which it would not do before. This will cost you nothing to try.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 08-13-2018, 07:34 AM   #10
bill3rail
bill3rail's Avatar
Re: What causes...
Still love this site, I find information that I did not know I needed. I did notice my hood popping up in the back and didn't think about it at all.
Thank you,
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 08-13-2018, 11:27 PM   #11
RMBLFSH
Re: What causes...
Great suggestions all.
Thank you.
Old 08-15-2018, 06:21 PM   #12
71CHEVYSHORTBED402
Re: What causes...
Just rec'd a can of that Seafoam and took it to the hinges on my 72 beater. Honest to God I've never seen a hood open/close so easily.
Tony
Old 08-21-2018, 08:49 AM   #13
RMBLFSH
Re: What causes...
Hey all,
I would like to report that Loc Doc's suggestion to loosen and rotate the hinges worked like a charm for me.
Trying this might save you a few bucks on buying hinges you may not need.
Thanks,
Rich
Old 08-21-2018, 12:00 PM   #14
LockDoc
LockDoc's Avatar
Re: What causes...
Originally Posted by RMBLFSH View Post
Hey all,
Thanks,
Rich
Good deal! Thanks for reporting back.
LockDoc
Leon
Old 08-23-2018, 10:49 PM   #15
71CHEVYSHORTBED402
Re: What causes...
Hey all,
Thanks,
Rich
I learned long ago if Loc Doc says it's so it's so. No pressure intended Loc Doc
Tony
Old 09-03-2019, 12:16 PM   #16
Signkutter
Re: What causes...
I have a problem with my hood kicking up in the rear like that on one side. All the bolts seem tight. after the hood is shut i can press down on the kicked-up side and it will sink down a good 3/16 inch...bad hinge?
Signkutter is offline   Reply With Quote
Old 09-03-2019, 12:53 PM   #17
LockDoc
LockDoc's Avatar
Re: What causes...
Follow the instructions I posted in post #5. I would try just the hinge on the side that is up first, but you may have to loosen both to make it work. You need 2 people to do it.
LockDoc
Leon
Old 09-03-2019, 01:04 PM   #18
Signkutter
Re: What causes...
LockDoc
It sounds like your instructions are for an empty engine bay....am I wrong in that assumption?
Old 09-03-2019, 01:33 PM   #19
LockDoc
LockDoc's Avatar
Re: What causes...
The instructions I posted are the same whether there is an engine in the truck or not. Wouldn't make a difference.....
Not sure what gave you that impression.
LockDoc
Leon
Old 09-03-2019, 03:20 PM   #20
Signkutter
Re: What causes...
LockDoc
Pushing up on the hood from the front. But I get it. I appreciate the information
Old 09-03-2019, 04:03 PM   #21
LockDoc
LockDoc's Avatar
Re: What causes...
No problem.
LockDoc
Leon
