#7126 |
Who Changed This?
![]() Join Date: Jan 2013
Re: What did you do to your truck today? Chapter II
That Chevelle is gorgeous. If it was mine, there'd be no chance for rust behind the rear tires. That area would have a nice layer of Goodyear PolyGlas GT coating it. I started work out of high school at a Chevy dealer. I loved driving those things!
#7127 |
Never throw away an old dizzy, you never know when you'll need a engine oil primer. Like that time I spun the oil primer on the drill in the air and I bent the shaft. One of those times.
Do it, Do it right, Do it right the first time |
#7128 |
![]() Join Date: Dec 2012
I drove mine to haul myself and my tools to repair the front brakes on a friend's car. It ran and sounded so damn good! I love these trucks!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#7129 |
![]() ![]() Join Date: Mar 2016
I drove to work and parked where I could look at my truck out the front window.I drive 16 miles round trip for lunch 4 days a week. I enjoy the drive ,sometimes I'll even turn on some music. I love my Chevy's.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() Last edited by 3757chevy; 08-11-2018 at 10:13 PM. |
#7130 |
#7131 |
I always use a bent up coat hanger or welding rod chucked into an old hand drill brace to pre oil engines ~ you needn't spin it fast, just long enough to register pressure on the gauge and have oil weeping out of the rocker lube holes .
The salvaged dizzy idea sounds pretty clever to me .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#7132 |
Washed the frame and undercarriage.
Zane's 71 Build |
#7133 | |
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
#7134 |
Getting started on some new parts. My first project truck. Sat for 20+ years. I can tell there are a few "new" parts that aren't OEM, but I think these plugs and wires are original 72. Whatcha think?
#7135 | |
![]() Quote:
No worries about the broken insulator, time to get upset when the bottom threaded part remains in the cylinder head..... ![]()
#7136 |
Installed ece front sway bar and drove it.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
#7137 |
![]() Join Date: Mar 2013
Flared a short section of stainless brake line. Failed to flare of section of brake line. I was trying to shorten a pair of stainless lines on my rear end to work with my disc brakes. The line and/or tool did not like the small 3/16" line... 1/4" line was perfect.
#7138 | |
Re: Pre - Oiling Engines
#7139 | |
Ground the teeth off of the gear and reduced top dia. for a 3/8" drill. Still keeps the shaft from sliding off of the pump slot. Haven't used it in years as the engine is still doing just fine! ![]() ![]() |
#7140 |
Got the pinion back in the rear with new bearings. No sleeve crush yet. Got the new carrier bearings installed and the ring gear switched over to the Eaton carrier, ready to go in. Started installing the brackets for the No Limit upper mount sway bar, and found I had a u bolt with striped threads. got to order a set. Also found my left rear brake line was almost mashed shut on the back of the axle. That must have been like that for years. But I am getting closer each day!
1968 SWB Step Side, Big Block, 4L80E , Running! |
#7141 |
#7142 |
Put a few miles on the new top end, and fried the alternator.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
#7143 |
Designated Grumpy Old Man
![]() Join Date: Oct 2001
Kind of counter productive but I sold mine today.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
#7144 |
![]() Join Date: Apr 2013
Replaced the heater hoses...while I was taking the wire clamp off the 5/8 inch hose, it popped out of my pliers, sailed into the driver’s side engine bay, rattled around and disappeared (that’s my conclusion after spending 30 minutes looking for it - which included taking the driver side front wheel off)
![]() Used hose clamps to secure the hoses on the heater core, then spent 20 minutes trying to get the metal thingie that holds the hoses together, failed, and just used a cable tie. I hope that clamp didn’t end up somewhere that will cause me problems later.... ![]()
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
#7145 |
This was yesterday... but I welded up some of the spot weld holes, and cut some of the firewall out.. had help with cleaning!!
#7146 |
Finished my rear end rebuild, and installed brake adjusting holes in my rear drum backing plates.
#7147 | ||
Who Changed This?
#7148 |
Today I finished the install of an auxiliary fuel tank. It's a 31 gallon unit which gets me about 50 gallons total as I have elected to keep the tank behind the seat. Looking forward to fewer (but more expensive) stops at the gas station which can be a real inconvenience with a travel trailer in tow.
#7149 | |
#7150 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
