08-14-2018, 04:47 PM | #1 |
Power Steering Bracket
Hello Gang, I installed a BluePrint engine in my 68 GMC and they suggest an 8 inch harmonic balancer. The p/s bracket that came on the truck is the cradle type that bolts to the 2 vertical holes, front of block next to the timing cover and that bracket will not allow me to use the 8" balancer. BTW, I am using a short water pump. How is everyone going about this issue if you are running something different than the standard balancer? Thank you!
08-14-2018, 05:11 PM | #2 |
Re: Power Steering Bracket
This sounds like what your talking about ,I just put a new 8" on it .
08-14-2018, 05:45 PM | #3 |
That's beautiful, and exactly what I am referring to. Can you post a pic of the bracket that you are using? I am not running a/c yet (future) but, I'm not a big fan of moving things around the motor either. Trying to keep the stock look while updating the 50 years of evolution.
BTW, That looks like the same bracket that I am using. Most repo houses say it is a Big Block bracket. Of course the more I ask here, the more I learn |
08-14-2018, 06:10 PM | #4 |
GM part # 3993314 '62-'72 small block multiple applications , Chevy truck , Nova, Chevelle
08-14-2018, 06:16 PM | #5 |
Where did you find a chrome one Grumpy?
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
08-14-2018, 06:22 PM | #6 |
Bought it off the parts board from another member , But then I had to have the stock alt bracket chromed and then may as well get chrome pulley's and chrome alt and chrome power steering pump and chrome oil pan and chrome timing cover and chrome 2 1/2" rams horn manifolds , It just keeps going chrome but that's what we used to do way back when
08-14-2018, 06:29 PM | #7 |
It's a vicious chrome circle I know all too well.
08-14-2018, 11:00 PM | #8 |
08-15-2018, 06:42 AM | #9 |
Two brackets together. It's not a great pic but I'm working on mine right now.
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. Last edited by 72LB; 08-15-2018 at 10:24 AM. |
09-28-2020, 11:32 AM | #10 |
Reviving an old post, but does any one know the number for the stamped rear bracket in these pictures that bolts to the engine mount?
09-28-2020, 12:26 PM | #11 | |
Here's one I found on Ebay . You can see in the pictures it has the same part # and "W" stamped -- https://www.ebay.com/itm/1971-1972-C...-/254649911260
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 09-28-2020 at 01:15 PM. |
09-28-2020, 05:08 PM | #12 |
Grumpy, thanks for the help.
09-28-2020, 09:40 PM | #13 |
Old member
This is the one i used on my short water pump. I cut the back bracket off and redrilled it. I had to make some mods to it as you can see in the pictures but it worked fine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
