Old 05-11-2004, 07:12 PM   #1
crazy longhorn
Fabricate till you "puke"
? for the guys running dropped spindles
I have been running cut coils on the longhorn for about 12yrs , & am looking to upgrade. at present (for time issues), a 2 1/2 " dropped spindle looks to be a good way to go. A 1 1/2" spring, or bags should put me where I want to be on "stance"(along with spindles). With a 2 1/2 drop spindles, are you guys haveing problems with the lower a arms scraping the pavement? thanks for any input, or options.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-11-2004, 07:45 PM   #2
cdowns
cdowns's Avatar
i've got spindles with 245x60x15 tires stock springs and i've got 31/2inches clearance for the a-arms haven't scraped them up in the 3years i've got them on
Old 05-12-2004, 12:05 AM   #3
low burb
I run 1.5 springs and 2.5 spindles and have for three years, no problems with hitting, ever. Michael
low burb is offline   Reply With Quote
Old 05-12-2004, 10:58 AM   #4
98L150
///Relaxed Atmosphere
98L150's Avatar
no probs here
I have 2 1/2 spindles with air bags on my burb and do not have problems unless I have the drive height extremely low were i now it will hit. But at normal driving conditions I have no problems.
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 05-12-2004, 08:02 PM   #5
crazy longhorn
Thanks for the input guys, it looks like 2 1/2" spindles & bags need to be on the front of my 69 the back will be a load of work....still runnin the leafs crazyL
Old 05-12-2004, 11:23 PM   #6
98L150
98L150's Avatar
attn crazy longhorn
On the leaf rear truck the crossmember at the below the rear cab wall of the truck has the mounting pounts already drilled i it for the factory trailing arms. You could installs these factory trailing arms the just add an early calssics adjustable panhard rod kit and an air ride tech kit for the rear and it would be a fairly simple install.
72 Suburban
64 Build Thread
Old 05-12-2004, 11:51 PM   #7
crazy longhorn
I wish it were that simple, but the longhorn is a different frame than the other pickups(same frame as a 133"wb 1 ton dump truck ). i think my best route will be a 4 bar & big step notch to fit the bags.... crazyL
Old 05-13-2004, 02:09 PM   #8
sactoC10
71 DELUX
sactoC10's Avatar
I also have the 2.5" drop spindles, with one coil removed from the stock springs...have note rubbe or bumped a thing.
sactoC10 is offline   Reply With Quote
Old 05-13-2004, 05:11 PM   #9
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Longhorn, For a quick and inexpensive fix try a flip kit for your leafs and remove a couple of the heavy springs out of the pack. You are not going to be hauling any heavy loads anyway with this setup. This will net you a 5+ inch drop in the rear. DJM supplies new poly bump stops in the the drop kit. The kit is only about $60 and includes new shock mount brackets too. I did this on my son's '77 with 2.5 inch spindles plus 2.0 inch springs (up front) and it was perfect. The rear was never a problem but your front cross member may pick up some gravel if you stray off the pavement...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 05-13-2004, 05:31 PM   #10
crazy longhorn
The rear isnt too big an issue(other than its still leaf), its been flipped. where the trouble comes in is the added weight to the rear(fuel cell)....good for traction/ride, but it set the @ss down, the truck sits level....& I like that "nose down " rake. im not done adding weight to the back(or moving it back anyway).....maybe a set of bags would be the ticket up front to give a little more "adjustment"? a big thanks for the heads up on the gravel "plowin" arms (off the beatin path).... crazyL
Old 05-18-2004, 02:31 AM   #11
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
2 1/2" spindles and 1 1/2" springs here... the only thing I've bottomed out are my cheapo long tube headers. I don't need bags to throw sparks.....
I wish I would have thought about lowering it when I bought those headers... Oh well more money to spend.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 05-18-2004, 06:35 PM   #12
crazy longhorn
the hooker comps i run are full lenght, but havent seen the pavement on a 3" drop. I think i can go another 1 - 2" on drop without problems.....(i hope). at any rate, the collector flanges hang about 2 1/4" below the rails on my longhorn......I think the eng crossmember would take the "roadrash" 1st. all my exhaust runs under the crossmembers, but is tucked up nice & tight. i have built 2 custom crossmembers, 1 for the trans, & 1 for the carrier bearing (2x6x1/4" wall)& notched on the bottom pretty good! i dont plan to lay this old truck on its belly, but would like a 4 1/2 -5 " front drop @ ride height, also with proper front geometry. Can you say VERY FINICKY! crazyl
