Old 05-12-2004, 12:15 AM   #1
72jimmy4x4
how much will 33 rub
How much will 33 rub on our trucks with out a lift kit and not wheeling to hard? Thinkin they look alot better with something in the wheel well and wont be lifting it for a few years.
Thanks all.
72jimmy4x4 is offline   Reply With Quote
Old 05-12-2004, 02:56 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
NONE.
I run stock suspension on my 71 Blazer with 33" all terain tires (they actually measure 32.5") on 15"X8" ralley rims and have flexed out my truck as much as it will with stock suspension.It has not rubbed anywhere.
Here's the other side.The rear is stuffed pretty good but it didn't rub.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 05-12-2004, 03:09 AM   #3
1970blazin
Blazerless:-(
1970blazin's Avatar
Cool to see someone enjoying and using their blazer BobbyK!! I love that color!!
1970blazin
1970 CST Blazer-Orig. Dark Blue-SOLD
Progress Pics of Blazer for sale
1970blazin is offline   Reply With Quote
Old 05-12-2004, 03:30 AM   #4
BobbyK
BobbyK's Avatar
Thanks Di...I kinda like it too!
While we're strokin ego's here.....Your Blazer continue's to amaze.
Prop's to you and your hubby!
Old 05-12-2004, 05:28 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have 33x12.50x15LTs on 10" rims on my '71 Jimmy, stock stance and no problem. I used to have a '67 K/10 Sub w/ 33x12.50x15LTs on 15" x8" rims and sometimes the rear tires would rub in the wheelwells, especially when driving in the mountains with a big load. Also when I tried the Jimmy's tires (on 15"x10" rims) on the Sub, the front tires rubbed real bad and jammed in the wheelwells. In conclusion, the Sub needs a lift as well as a lot of other stuff to get it running again. LOL.
Old 05-12-2004, 07:03 AM   #6
vtblazer
vtblazer's Avatar
33's
33's look great on a stock blazer but I didn't have the same luck as the other's at a local RV/Snow machine dealers place, everytime I pulled out of his driveway (right and up) my passenger side tire hit the lower portion of the right fender. I was running 10 inch wheels...maybe the offset was causing it?
Otherwise no real problems running 33's.
Yep, BobbyK...nice to see a different color I'd say the 8" ralley's are the way to go w/33's.
vtblazer is offline   Reply With Quote
Old 05-12-2004, 12:21 PM   #7
72jimmy4x4
Looks like the 8in will be the best thanks all.
Old 05-12-2004, 04:38 PM   #8
jamie72
jamie72's Avatar
i run a 33-12.5-15 on an 8in rim and i have no lift,it has never rubbed...
go with and 8in and i think you`ll be fine.
jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-12-2004, 05:30 PM   #9
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
I had 33 on my old blazer with no problems
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
