08-24-2018, 02:22 PM | #76 |
But Found Her 25yrs Later!
Re: F/S OE 72 Big Block Parts, Brackets, Stove Pipe, Air Cleaner, Towers and/or Reque
Do you ever come across Barden Bumpers?
I'm looking for one local but has the Woodland CA plate.
08-28-2018, 02:29 AM | #77 |
Always on the hunt...
All of the big block parts pictured in above post #73 & #74 are headed your way, the package went out via FedEx home delivery on Mon. 08/27 and as of this evening, the FedEx website is projecting that you should see the parts this Sat. 09/01 by the end of the day. Thanks again and let us know if we can help with anything else 67-72 related in the future, Mel
09-02-2018, 10:25 PM | #78 |
“On The Hunt”
I’ll take the OE 72 big block engine tower/clam shell setup for 200
02-25-2019, 02:23 PM | #79 |
Sent you a PM looking for a w/p pulley?
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
02-26-2019, 01:51 AM | #80 |
The 648 BBC water pump pulley part number that you sent via pm would not be correct for a 68 BBC with A/C, the 648 was a later style BBC SWP 2 groove w/p pulley. If trying to stay OE, we do have a 68 with A/C two groove 419 BBC water pump pulley available, this upper 419 BBC water pump pulley matches/goes with the lower two groove 414 BBC inner crank pulley. Cost would be $65. + $8. for USPS shipping, if interested payment can be sent via USPS moneyorder, paypal or credit card over the phone. Let me know, Mel
02-26-2019, 10:22 AM | #81 |
Shoot, I am getting my butt kick on this pulley setup. ok so I previously purchased a complete setup from another member and the pulleys are wrong.
so this is what I have. Crank 3876844 outer crank 3925525 p/s not sure would have to look w/p 3995646. Well, do you have a complete pulley kit for 68? I think the only correct one is the outer crank pulley and I would hope the p/s pulley. I will take the w/p pulley, pending that hopefully you have the others.
02-26-2019, 08:53 PM | #82 | |
We do have the correct A/C application 414 BQ BBC 2 groove inner crank pulley (pictured below) available for $50., and could ship it along with the matching A/C 419 CT BBC w/p pulley that we offered you above, shipping on both pulleys combined would be $15. Let us know, Mel . |
02-27-2019, 09:56 AM | #83 |
I will take both pulleys. I will pay Via PP.
02-27-2019, 02:55 PM | #84 |
02-27-2019, 04:27 PM | #85 |
Hey Mel
Would you happen to have a Z bar for a big block truck by chance? I have a 72 C-20 with a 402 4-spd and the Zbar in it has been welded on and isn't quite right Thanks Tim |
02-28-2019, 03:57 AM | #86 |
Your BBC water pump and crank pulleys have been shipped off and tracking number returned, the package went out via USPS priority on Wed. 02/27 and USPS has projected that the package will be delivered this Sat. 03/02. Thanks again, Mel
03-04-2019, 08:27 PM | #87 |
Mel, PM sent regarding BB pulleys.
03-07-2019, 02:05 PM | #88 |
Received pulleys on Saturday and they worked great.
Thanks Mel
03-09-2019, 12:03 AM | #89 |
Thanks for confirming arrival and was glad to help get your BBC pulley issues sorted out, did you try to contact the other seller that sold you the previously purchased "big block" pulleys? Let me know if we can help with anything else 68-72 big block related.
Hello, sorry about missing your pm and the delayed response, we hadn't been around here for a few days and after searching for your pm, I found it was attached to some older messages from our past dealings under the subject heading nos moldings. We should have all of the BBC pulleys on hand besides the 68 big block (one year) 2 groove w/p pulley for a/c, we only had the one that was pictured/sold above, if not planning for a/c we would have the 68 big block single groove w/p pulley available. I can take a look tomorrow, Sat. 03/08 and confirm/let you know what we have available ready to ship. Mel |
06-01-2019, 03:56 PM | #90 |
would the 1972 power steering and alternator brackets be the same as a 1988 mark 4 block and heads? If so, I am interested in both and a set of 72 and up motor nount brackets/stands
67 C20/ 68 C10 stepside/inline 250--current project 71 GMC 4x4 70 Blazer project-Zombie assault vehicle 67 4x4 Burb |
08-12-2019, 06:41 AM | #91 |
Do you have a clutch pivot bracket. The one on side of block
08-17-2019, 09:13 PM | #92 |
Do you still have the alternator bracket for the BBC?
08-29-2019, 02:14 PM | #93 | |
Are you needing the bell crank pivot ball stud for a big block, see below BBC pivot Id pics? Confirm motor size and we can check on this for you, the below pictured BBC pivot ball was recently sold to a board member in Canada. Confirm the year/style (see below) of BBC alternator brackets that you are needing/asking for and we can check on availability and get you some pictures. Thanks, Mel |
08-29-2019, 02:17 PM | #94 |
Last BBC alternator bracket Id pic...
10-06-2019, 10:10 AM | #95 |
Looking for 1968 bbc ac brackets for swp. I have the intake manifold bracket and arm as well as the front compressor plate but need the rest.
10-07-2019, 05:40 PM | #96 |
Do you still have the clutch z bar bracket
10-10-2019, 07:26 AM | #97 |
On the road
Hi Mel,
would you happen to have another BB fan shroud?
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
10-14-2019, 08:21 PM | #98 | |
10-14-2019, 08:46 PM | #99 |
That pictured engine side BBC bellcrank/z bar pivot ball stud seen earlier in thread has been sold/shipped, we do have another original BBC bellcrank pivot ball stud available, this one was removed from an original 72 C/20 402 big block truck. $165. + $10. for the ride, payment can be sent via US postal moneyorder, paypal or credit card over the phone. Let us know, Mel
10-14-2019, 09:10 PM | #100 |
Hello Mike, we do have this extra nice OE BBC fan shroud on hand/available @ $150. + shipping, probably expect $50.-$60. for safely packed double boxed fedex shipment. If you let me know your shipping Zip and confirm if business or residential I can get the fedex ship cost, this may be one of them parts that you would want to find closer to home, maybe a pick up in hand type deal. Let me know, Mel
. Last edited by Classic Bowties; 10-16-2019 at 11:28 PM. |
