![]() Join Date: Apr 2000
newer 8 lug rear
looking at swapping a newer rear axle in my 71 k20,any issuses? i need to change gears, and find a carrior for my old one but found a 2000 with rear discs and the right gears for way less.. i know i`ll have to move perches and shock mounts, anything else i`m missing?
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
![]() Join Date: Oct 2009
Re: newer 8 lug rear
Keep in mind a 2000 will have metric wheel studs and rear disks will require some master cylinder re-thinking.
Add changing gear ratio in the front axle to match the rear
just bought the truck the 44 up front has complete rebuild..in 410 the back had some water in axle.. so the gears are rusty,and i want disc on rear..
Track width is also different, wheels will look odd in the rear.
All about them K’s
![]() Join Date: Jun 2014
Yep exactly also the American studs can be swapped in place of the metrics. I’ve got 2 disk 14s out of mid 00s trucks and I’ve swapped the studs already on one of them.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() Last edited by 57taskforce; 08-30-2018 at 06:27 PM. |
