![]() Join Date: Sep 2007
What does this Iine do
And where or what do I hook it up to on my 67 c10 ls conversion? It's a 2003 dbw and the line I'm talking about is attached to the housing on top of the engine in front of the manifold with the green tab on it. It runs parralel with the fuel lines. Help is appreciated!!!
1967custom |
Re: What does this Iine do
That may be the EVAP line. I deleted that on mine.
That's for the evap. You don't need it. You can leave it in the manifold or get or make a block off for it.
cool thanks guys. im gonna cut and plug it then
1967custom |
ICT billet makes a block off kit on amazon. You can get EVAP and EGR block plates together
If you're putting the Vortec cover back on, you can just take the line off the solenoid. Its normally closed so as long as it doesn't have power going to it it will be blocked off assuming the solenoid is good of course.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
can I just cut it off with a razor?
1967custom |
I suppose you could, but it would be easier to just push the little white tab on the fitting (on the driver's side) and then pull strait up and the line will come off.
