Old 08-30-2018, 09:47 AM   #1
solidaxel
solidaxel's Avatar
F E Drive
Has anyone used this water pump?
What H balancer does it require?
Holley Performance 20-185 Mid-Mount LS Accessory Drive System Kit
Holley's Mid-Mount complete accessory system has all accessories pulled in tighter than other accessory drives. Among the many swap, friendly features is the bracket-less assembly that actually mounts all accessories to the water pump directly.olley Performance 20-185 Mid-Mount LS Accessory Drive System Kit
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-30-2018, 02:40 PM   #2
71cadc10
71cadc10's Avatar
Re: F E Drive
it comes with the crank pulley / balancer for the crank.
you have to use their pulley, I don't think it matches any of the corvette/Fbody/Truck balancers exactly.
If you want one with a tru harmonic balancer, the kit 200-180 comes with the ATI balancer instead of the stock type GM pulley
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 08-31-2018, 09:15 AM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: F E Drive
I wouldn't buy that kit... if the waterpump fails one day, you'll be stranded and have to order the pump and hope they have them instock/not discontinued.
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 08-31-2018, 09:20 AM   #4
solidaxel
solidaxel's Avatar
Re: F E Drive
Good point!
So the water pump is a "Holley" brand not off the shelf
not like the early V8 riser castings with the 6 cylinder water pump
LS 3 4L70E
Old 08-31-2018, 09:28 AM   #5
oldman3
oldman3's Avatar
Re: F E Drive
Solid, now your going back to "the day", haven't thought about those in years...Jim
oldman3 is offline   Reply With Quote
Old 08-31-2018, 12:29 PM   #6
87chevy.com
Re: F E Drive
Good point!
Maybe, probably need to see if that pump is a factory part to make sure.
