Old 05-12-2004, 06:54 PM   #1
shavedchevy
shavedchevy's Avatar
Question People with shave door handles
what spring loaded poppers do you use. I'm getting a pair of new ones because the one that came with the kit are garbage and don't open the door enough to fully unlatch it.
Dennis
shavedchevy is offline   Reply With Quote
Old 05-12-2004, 07:16 PM   #2
cochino12
It followed me home?
cochino12's Avatar
I use a brake spring. Are you sure the latch or door is opening correctly? I went a few months without a spring and had no problem at all
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 05-12-2004, 07:25 PM   #3
shavedchevy
The latch and everything seems to be good. My prob is that when the door unlatches it catches the safety catch and I have to pop the door for a second time while pulling on the door..... it just doesn't look like the popper has a long enough stroke to fully push the door open. So I figer I just need a better quality popper.
Also.... where is the popper mounted..... mine is at the bottom corner where the rubber door stop used to be.( Just a dumb question)
Dennis
Old 05-12-2004, 11:28 PM   #4
bagged74
its just $$$$$
bagged74's Avatar
I never used a popper on my blazer. It always popped open with no problem, well except the one time the battery went dead.
bagged74 is offline   Reply With Quote
