Old 08-31-2018, 09:07 PM   #851
dave6672
dave6672's Avatar
Re: Lets see pics of your truck hauling!!
1972 C20 Highlander with 2 tons of gravel and my daughter riding shotgun!
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
dave6672 is offline   Reply With Quote
Old 08-31-2018, 10:29 PM   #852
bautino95
Active Member
My friends stepside helping me out
bautino95 is offline   Reply With Quote
Old 09-01-2018, 10:23 PM   #853
Luvinit
Luvinit's Avatar
My 72 c20 longhorn with a 72 Sportsman camper. The springs handle the load but that unboxed old style frame has a whole lot of sway in it.
1972 Cheyenne Longhorn k20, 402, A/C
Luvinit is offline   Reply With Quote
Old 09-01-2018, 10:26 PM   #854
weq92f
weq92f's Avatar
Pic of the week!
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 09-01-2018, 11:36 PM   #855
Steeveedee
Who Changed This?
Steeveedee's Avatar
That's a lot of weight mounted high, which has increases the moment of inertia. If it doesn't have a rear stabilizer bar, it should. Even after just putting Firestone Transforce tires on my truck, I noticed over steer with the new camper shell, even though I run 10 PSI higher pressure in the rear tires. Didn't have that problem with the old Michelins, but they don't make that size any more. It's a problem, even with the equalizer hitch. Since I tow a 26 foot travel trailer, I'll be balancing out the suspension with a rear stabilizer bar.
~Steven
Simi Valley, CA
Old 09-03-2018, 12:20 PM   #856
eastxbbqman
eastxbbqman's Avatar
Not towing much... 3.08 gears
eastxbbqman is offline   Reply With Quote
Old 09-05-2018, 08:52 PM   #857
This truck did a lot of parts hauling
Old 09-05-2018, 09:14 PM   #858
heavymech
heavymech's Avatar
Just a golf cart.
heavymech is offline   Reply With Quote
Old 09-07-2018, 02:09 AM   #859
charles_c12
5035lbs of retaining wall blocks about 40lbs shy of the trucks total weight
charles_c12 is offline   Reply With Quote
Old 09-10-2018, 12:11 PM   #860
Malibu Monte
Cleaned up some brush around home last Friday.
-Monte
72 Chevy K10
Malibu Monte is offline   Reply With Quote
Old 09-10-2018, 09:04 PM   #861
uncle
Ton hauling a horn.
uncle is offline   Reply With Quote
Old 09-10-2018, 09:13 PM   #862
Jeff's bowtie's
Looked like you were losing your load so I'll right side You up
Jeff's bowtie's is offline   Reply With Quote
Old 09-10-2018, 09:33 PM   #863
uncle
Thanks.
Old 09-11-2018, 09:09 PM   #864
VWNate1
VWNate1's Avatar
Thumbs up Ton Hauling Another Ton !!
Wherever you live, I like it .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 09-12-2018, 06:48 AM   #865
No need for boxed frames. These frames were quite strong. My camper was a bit smaller than yours but my '71 Custom Camper rode flat and stable with the camper mounted and loaded up. Maybe the springs are tired (leaf, right?) or shocks are bad. Also, it appears to be slid back from the cab close to a foot. That will cause sway due to poor weight distribution. Is the bumper in the way of sliding it up? I didn't have a rear stabilizer, but I did slap 33/12.50s on 9.75 rims on when I bought it. Wider tires would do wonders for your truck.
Old 09-13-2018, 09:15 PM   #866
72 tigger
72 tigger's Avatar
Pulling my “trash trailer “. I remodel kitchens and bathrooms and throw anything that won’t burn in it. Finally took some time to show it a little attention. New tires, painted the wheels and sideboards and cleaned it up. Hopefully good to go for a while.
72 tigger is offline   Reply With Quote
Old 09-13-2018, 10:38 PM   #867
WorkinLonghorn
WorkinLonghorn's Avatar
That's a long horn too. One ton frame. Mine had that gap too. Did they even make a camper to fit that 8 1/2' bed? -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 09-14-2018, 01:41 PM   #868
TIMCHNE
On the way to the track
TIMCHNE is offline   Reply With Quote
Old 09-14-2018, 02:14 PM   #869
RDrancher
RDrancher's Avatar
That's one heck of a first post. Nice and welcome!
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 09-14-2018, 02:25 PM   #870
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yup. I have one on mine.
I think that I have solved the mystery of not having "Longhorn" emblems on the fenders. The bed is tweaked a little, so it was probably hit sometime before '73 when my FiL bought it. He's never mentioned it getting hit, that's why I say before. Can't ask him, since he died 9 years ago. Whoever did the body work probably just left the trim off. The SPID says 133" wheel base, so it's a true Longhorn. I'll check someday if it has bondo or braze there.
~Steven
Simi Valley, CA
Old 09-14-2018, 03:08 PM   #871
3757chevy
3757chevy's Avatar
Welcome aboard.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is online now   Reply With Quote
Old 09-15-2018, 05:19 PM   #872
I kept looking and still wasn't sure if it was a Longhorn. Didn't think it was. But, yeah, some companies for that time period made a model specific for Longhorns.
Old 09-22-2018, 06:04 PM   #873
HO455
HO455's Avatar
Not much of a load but its long! A couple sheets of 4x10 MDO underneath the 12 footers. Mama wants book cases!
RIP Bob Parks.
Old 09-24-2018, 11:11 AM   #874
WorkinLonghorn
Nice rig. That's the first one I've seen that fits.
Old 09-24-2018, 11:20 AM   #875
davischevy
Your truck, your guess, Steve, but I'm inclined to think they just failed to install the emblems. Their used to be an ochre Longhorn here in town that didn't show any sign of ever having the emblems.
BTW, that truck and camper looks great.
davischevy is offline   Reply With Quote
