Old 09-01-2018, 12:46 PM   #1
Materi1
Airbags/shocks
I put a ‘80 front end on my ‘63. I just cupped the lower control arms 2”. I will also be putting bags in the rear on the trailing arms where the coils sat. What shocks do i need? Factory length or shortened ones? I was planning on using stock with relocates.
Materi1 is offline   Reply With Quote
Old 09-02-2018, 09:39 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Airbags/shocks
Remoed
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-03-2018, 01:15 PM   #3
Materi1
Re: Airbags/shocks
K that makes sense. I was hoping i could of just got away with buying factory length shocks ahead of time but i guess i will wait till i get it finished first than select shocks. Did you do shock relocates??
Old 09-03-2018, 02:22 PM   #4
CousinTone
Re: Airbags/shocks
Measure the angle the top is set off from the top, you want to get back to this angle, or within a couple of degrees, your good. So now, do your drop and remeasure. When you’re done, take a look at the new angle. I don’t know the specific degree, but if your mounting point is moved and it appears to be too far away from your stock degree measurement before drop, mark the frame where the mount needs to relocate to and straighten it back to as close to stock as toy are able. Others chime in here, if you have a different method, but that’s what I did and it worked out ok so far
CousinTone is offline   Reply With Quote
Old 09-03-2018, 04:01 PM   #5
vin63
vin63's Avatar
Re: Airbags/shocks
Removed
Old 09-03-2018, 09:34 PM   #6
Materi1
Re: Airbags/shocks
I built a set of relocates like POL carries the other day at work for the front. For the rear i am gonna use the factory lowers but switch left to right/right to left and use the top mounts from the front for the rear tops. Do you want rear shocks straight up and down or some degrees to them??
