Old 09-01-2018, 09:35 PM   #1
68ihscout
Oil pan gasket help
My pan measures 2 3/8 and calls for the new style gasket which should be os-34510-T ,i got what i thought was right for 1970 c20 350 which is felpro 1885 i think is the old style ,..any help is apreciated
68ihscout is offline   Reply With Quote
Old 09-02-2018, 08:34 AM   #2
geezer#99
geezer#99's Avatar
Re: Oil pan gasket help
If you measured right, then it would seem you got the wrong one.
The 1885 is a thin front seal.
Shows that here.
https://www.jegs.com/i/Fel-Pro/375/1885/10002/-1
You might need this one.
https://www.jegs.com/i/Fel-Pro/375/OS34510T/10002/-1
Old 09-02-2018, 11:15 AM   #3
68ihscout
Shows that here.
i rechecked the measurements many times ,i even put the gasket on that side and it was short at bottom by about 1/8 “ when i lined up the bolt holes.
Thanks G
Old 09-03-2018, 03:23 PM   #4
68 P.O.S.
The trucks I've had always used the 375-OS34510T gasket above.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 09-04-2018, 10:48 PM   #5
68ihscout
i just got that one
Old 09-05-2018, 12:02 AM   #6
jeffahart
jeffahart's Avatar
That was the one to get. You get the gasket and the alignment pegs and new bolts for same price as driver dip only. Only difference is FEL-OS34510T can be used for either side dip. Great gaskets, easy install and no leaks.
j
White K20
jeffahart is offline   Reply With Quote
Old 09-05-2018, 02:42 AM   #7
Mike_The_Grad
Mike_The_Grad's Avatar
I actually just went through this entire thing last week. What a PITA. I wish you luck.
Anyways to your question. If you currently have your original oil pan on your vehicle you more than likely have the THIN front seal. This was the case on my 1972 c10 sbc350.
I was in the middle of an oil change when I went to reinstall the drain plug it turned and turned and turned and turned, you get the point. Well I found out they make an oversized drain plug. When i went to go get one from my parts guy, he had the exact same plug on the counter that I had in my oil pan. Oh great I thought. That left me with 2 options: A "Timesert repair kit"(Amazon order), or a new pan. I needed to get back on the road asap so I dug deep in my wallet and had him order me a replacement oil pan, Fel-Pro one piece gasket, and he had an ARP boltset on the shelf for the pan. Total came out to $120. And I had it in my hands in 2 hours.
So, the story on the gaskets. Any factory installed oil pan After about 1975 was of the THICK front seal type. Pre -75 for the most Part was THIN front seal. Almost all REPLACEMENT oil plans are THICK front seal. The replacement pan I received was a THICK front seal, the 1-piece felpro gasket I received was OS-034510-T. It is the THICK front seal type gasket And it is the correct gasket for my replacement oil pan. This mainly applies to stock configurations.(oe pan and oe timing cover.) Almost all aftermarket pans and timing covers are the THICK front seal type. All aluminum pans and/or timing covers are THICK front seal.
My setup being stock-ish was the thin front seal type but the new pan changed that regardless of my timing cover being stock and also original.
The OS34510T gasket is thicker than the 4 piece type gaskets and has a provision for either a left hand or right hand dipstick( the opposite side just sticks out past the edge of the pan slightly.) The bolts need to have at least 5/8" of thread length under the bolt head to work with the 1piece gaskets. Stock bolts WILL NOT WORK. Also the ARP bolt set for sbc350 oil pans Part# 234-1801 are for STOCK oil pans with the 4 piece gaskets. These are to short and WILL NOT WORK. ARP bolt kit Part# 134-1801 is for the 1-PIECE oil pan gasket ONLY. And the one that is correct for the felpro gasket OS34510T. I know this because I found out the hard way. I returned the ARP bolts i bought and my parts guy(which is awesome by the way) made me a Stud kit for my oil pan with studs he had in stock (Not ARP's) for $20! Took them home and proceeded to finish the oil pan swap. Took me A LONG time to do it. But all in all it was worth it because it doesnt leak and i have studs holding in my new oil pan. Hopefully you find this info helpful.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Mike_The_Grad is offline   Reply With Quote
Old 09-05-2018, 03:34 PM   #8
68ihscout
good info ,thanks ,the gasket did come with all new bolts ,ill have to compare them to the ones i took off.
