#1126 |
Re: LS1 into a 73 cheyenne
Thank you mud man
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios |
#1127 |
Got around wrapping up the rear axle . I touched up the POR15 Silver areas I installed new stainless tub bolts and finalized the brake assembly, installed the brake pads. still amazes me the hole system works. From a Frankenstein mess of parts, No assistance from a specialized team one man show
#1128 | |
When you say tub bolts do you mean like at wheel tubs? If so, all good. Reason I ask is that Jeep guys call the main body "the tub" and I'd be concerned if you used SS bolts at body mounts. I have some on the core support of my Cutlass that I re-did the front end on a long time ago and learned I need to replace. I didn't realize at the time that the stainless bolts were not up to the strength of chassis bolts. |
#1129 |
pics of the final assembly. Brake pads are in there really easy to install or remove there only held by the side studs on the caliper torqued to 40NM. Im going to keep that rear stance as it tucking nicely and still have like 2'' of travel before bottoming out
#1130 | |
#1131 |
Top got done, new knock censors and harness
#1132 |
got a pic my wife wanted of the boys and the hot wagon i built for them next to dads truck.
#1133 |
got a few pics of the engine. The intake manifold is not bolted yet, its primer white i will be painting it like a cream tone to match interior ulphostery
#1134 |
![]() Join Date: Mar 2011
Cool pic with the boys, engine looks great...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#1135 |
#1136 |
Still Learning
Very clean! Looks great Alex!
#1137 |
Any new updates? This thing should really get some attention at the Brothers shows!
77 C10 Silverado SWB - LS Swap, mechanical resto-mod 05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e |
#1138 |
Oh ya!!!!
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
#1139 |
![]() ![]() Join Date: May 2015
Great looking install!
#1140 |
Thanks everyone, it’s appreciated.
Progress is slow I only get to work on it on sundays. I did manage to align the alternator and space out the water pump cover. I also installed the alternator bullet pulley, and I installed an aluminum coil pack frame and the spark plugs
#1141 |
#1142 |
Here’s pic of the alternator spacing with new pulley
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios Last edited by smokedat; 09-12-2018 at 09:30 PM. |
#1143 |
I need to finalize the intake manifold, Il be painting it cream tone and change the the throttle body to a Holley 92mm and change the bottom seals and a new throttle link bracket form lokar
#1144 |
I was contemplating a fabricated aluminum intake manifold like the Holley sniper, but that would require more mods to install a throttle bracket this had to be done secured bullet proof status and it would require that I redo my fuel delivery up to the fuel rails, at this point I’m done chasing out problems finding solutions to custom fit applications.
#1145 |
Here are the components for my rebuild of the manifold.
#1146 |
You should chrome out the alternator. They can be taken apart easily.
#1147 |
here with the painted manifold and new throttle body.
#1148 |
Before and after
#1149 |
The color tone got lighter after it fully dried. I will be doing my interior door panels and seats this color Santa Fe
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios Last edited by smokedat; 09-15-2018 at 08:01 PM. |
#1150 |
Your truck will be so beautiful you may not want to drive it, but sure hope you do....a lot.
Really coming along nicely, appreciate your attention to detail. Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
Tags |
73c10, c10, cheyenne, ls1, swap |
