Old 09-03-2018, 09:31 PM   #1
bautino95
Not putting groove in new bed wood for hold down strip?
has anyone ever not put the groove into new bed wood for the hold down metal strip? I'm re-doing my old rotted wood bed with composite decking that I got from Lowes. I got my new spacing figured out because its only 5-1/2" wide. And had to rip the thickness down to 3/4" because it was 1" thick. So what do you think? will it have enough clamping force for hold the decking in place without cutting the groove into it? Thanks
bautino95 is offline   Reply With Quote
Old 09-04-2018, 07:56 AM   #2
Re: Not putting groove in new bed wood for hold down strip?
I dunno, I'd do a groove. Why not? It locks things in place and puts the ridges just above the floor. Looks great, too.
Old 09-04-2018, 10:11 AM   #3
davepl
davepl's Avatar
The groove locks it side to side but allows for end to end sliding. I'm guessing if it were possible to do properly without the groove, GM would have done so to save money. GM was huge about saving money. If you see a cotter pin on this truck, it's NEEDED, don't take it out.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-04-2018, 01:21 PM   #4
bautino95
The only real reason I don't want to do the groove is the decking says that it has some kind of protective wrap layer. So I didn't want to cut into that. I think I do a test piece and see what happens.
Old 09-04-2018, 01:51 PM   #5
jeffahart
jeffahart's Avatar
I would just cut the dado's. If you don't, you have to lose the factory strips. You could make your own from flat iron from Industrial metal supply. But seems counter productive.
If you cannot dado the material... how can you rip or crosscut?
I say don't over-think and dado away!
j
White K20
jeffahart is offline   Reply With Quote
Old 09-04-2018, 08:51 PM   #6
6T7 C10
I am thinking you could get away without the grooves but the strips would sit higher instead of flush with the floor. If you are okay with that then it is an option. Share some pics once you are done.
6T7 C10 is offline   Reply With Quote
Old 09-04-2018, 09:00 PM   #7
1968aj
this iswhat it will look like. installed about a year ago and sits outside.
1968aj is offline   Reply With Quote
Old 09-04-2018, 09:00 PM   #8
rockyrivermark
Sounds line pvc coated composit.
I think it would still look best with the grooves cut in the planks.
You really don't see much at all of the exposed cut
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 09-07-2018, 09:12 AM   #9
bill3rail
bill3rail's Avatar
The grooves set the bed strips level with the wood so you do not have them sticking up.
Cut the grooves, they are simple enough to do.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
