Old 09-03-2018, 09:36 PM   #26
weq92f
weq92f's Avatar
Re: Why is drum to disc called an upgrade?
Originally Posted by dmjlambert View Post
How do we get ABS for our 67-72 trucks?
My guess is the aftermarket is shy of this due to potential liability, however according to this 5 year old reference:
https://www.pro-touring.com/threads/...ket-ABS-system
There are these options:
High end: Bosch system, price range 6300 tot 7800 euros
Mid range: BMW Teves M60 ABS price range 4500 tot 5000
But they tell, bosch is best by far and most adjustable.. all topteams on le mans seems to use it they said..
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 09-03-2018, 10:20 PM   #27
Steeveedee
Who Changed This?
Steeveedee's Avatar
Smart money would be to find a newer truck with the goodies and dog rob the parts. You'll need sensors and so forth which will likely mean changing the rear axle. I don't remember how it was configured on my 2000 Astro van, which wouldn't work for you unless you had 5 lugs.
~Steven
Simi Valley, CA
Old 09-03-2018, 10:42 PM   #28
pritch
pritch's Avatar
Just keep the drums!
Seriously though, my drums are all new, well 15,000 miles ago, and with power brakes they'll stop 'Ol Green pretty well. But I'm going with front discs on my Panel build.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 09-04-2018, 01:01 AM   #29
toolboxchev
Yikes! ABS on my vintage vehicle. Some are different than others.
toolboxchev is offline   Reply With Quote
Old 09-04-2018, 07:53 AM   #30
Grumpy old man
Grumpy old man's Avatar
"Re: Why is drum to disc called an upgrade? "
The plain and simple truth is because it is an upgrade . Some guys are just fine with drum brakes ...Some aren't
If your looking at doing 100' power brake burnouts ( which in an empty bed pick up isn't hard to do ) don't upgrade to 4 wheel discs ,You'll just end up smoking your trans or clutch .
Old 09-05-2018, 10:06 AM   #31
MARKDTN
Probably don't is the simple answer. ABS is designed for a specific vehicle. A lot of money is spent tuning for that specific truck. You can't retrofit and expect it to perform. I have wondered if an '88ish rear ABS only system might could be made to work, but I would not try it. You would have to have that axle to get the sensor and on and on. The only way that might be safe would be a chassis swap and keep everything-even then you are not going to have the same weight balance as the original vehicle.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 09-05-2018, 10:37 AM   #32
4carbcorvair
I've had many cars over the years and currently do that have drums on all 4. When they get wet, really wet, you can't stop.
68 K20 Custom Camper/CST Wrecker.
97 GMC K1500 short bed reg cab.
4carbcorvair is offline   Reply With Quote
Old 09-05-2018, 10:59 AM   #33
sick472
sick472's Avatar
I have a 67 Pontiac with power drums all the way around and if the car is moving, you are also contemplating the next stop. It's a whole different way of driving! I also have a 67 ford with power disc conversions all the way around...it stops real good compared to the Pontiac. In fact, the Pontiac will lock up the brakes for emergencies, but your back side will be out of the seat under the pressure you have to apply and the urgency involved causes a strong knee jerk reaction, once she stops...you start breathing again. It will get front disk brakes with the next going through.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 09-05-2018, 11:10 AM   #34
Steeveedee
Who Changed This?
Steeveedee's Avatar
A lot of people don't appreciate the engineering that goes into brake design. For example, they'll slap a master cylinder from a Corvette on their Buick or pickup, never mind that the Corvette has really close to a 50/50 weight distribution. And look what is done with a lot of the rat rods. Some of these vehicles are just plain dangerous.
That said, as long as the brakes are properly sized for the application, the ABS could be added, because the real function there is to limit brake lockup.
~Steven
Simi Valley, CA
Old 09-05-2018, 12:07 PM   #35
Killer Bee
Killer Bee's Avatar
sensible driving is the best upgrade, sadly not an option for some people..
Old 09-05-2018, 01:58 PM   #36
jeffahart
jeffahart's Avatar
Thanks KB. I've had every excuse. Now next time I get pulled over I'll drop the glove box door and point to the SPID... "Look man, I didn't get the sensible driver option. Sorry, couldn't afford it when I ordered the truck!"
Nice get out of ticket free card!
j
White K20
jeffahart is offline   Reply With Quote
Old 09-05-2018, 05:55 PM   #37
plowro8
You usually get better strength and effectiveness when you pull/squeeze/supinate, rather than push/press apart/pronate. Disc is far better than drum... physics tells us so, and actions speak volumes.
plowro8 is offline   Reply With Quote
Old 09-05-2018, 06:27 PM   #38
Orange67
Orange67's Avatar
As stated before, the 4 wheel lock up associated with 4 wheel drums is exciting, but after what happened to me last year, my 67 will be getting front discs.
I was in the right hand lane on a four lane road, two kids pulled out from a parking lot to my left heading the same direction, I'm in the right lane, so they had plenty of room, right? Nope. They didnt even look, came right over into my lane causing me to jerk the wheel to the right and stab the brakes which spun the back end around in a really cool (if embarrassing) slide that i managed to stop about 6 ft from a telephone pole aimed at my drivers door. This may still happen with front discs, but I'm using it as a great excuse with the wife....
Oh yeah, and that was this time of year on dry roads to boot.
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 09-05-2018, 06:48 PM   #39
brad_man_72
the boat guy
brad_man_72's Avatar
I have found that disc brakes are easier to modulate near lockup. Sure drums can lock the tires but that's not ideal in most situations.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 09-06-2018, 08:48 AM   #40
68Stepbed
68Stepbed's Avatar
This thread is disturbing! I can't believe some of you actually prefer 4 wheel drum over disc brakes.
Apart from a sway bar, the disc brake "upgrade" was the best and most notable upgrade I ever made on my truck! Maybe it's because I live in the hills of east TN and not in the flat plains of Texas or Kansas.
As far as the folks complaining about the cost of the disc upgrade, exactly how much is your life or the lives of your family members really worth? Just Sayin'!
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-06-2018, 08:51 AM   #41
68Stepbed
68Stepbed's Avatar
It's the same as the old saying about traction for racing, "Spinning ain't winning." Well, when brakes are locked up and sliding, the vehicle isn't slowing down as quick.
Matt
Old 09-06-2018, 09:51 AM   #42
Grumpy old man
Here in Tn when they paint those white lines on the side of the road ,It's no Joke !
Old 09-06-2018, 09:54 AM   #43
Grumpy old man
Don't over drive your equipment
Old 09-06-2018, 10:44 AM   #44
Patch
Patch's Avatar
Growing up, my first car was a 1965 Dodge Dart. Leaning tower of power, 3 speed OTC and 4 wheel drum brakes with a single reservoir master cylinder. Cars like this to a young kid will either 1: Get you in all kinds of trouble in rainy Oregon, or 2: Teach you to drive in a very thought out and decisive manner. Coming down off of a local mountain,(the steep type, cut originally for logging trucks) I learned of something new to me called brake fade.....it wasn't fun. The non syncro 3 speed wasn't much help either. We made it down safely but I paid MUCH more attention to situations like that. Disc brakes to me are definitely an upgrade if for nothing else besides keeping that from happening again.
Patch
Patch is offline   Reply With Quote
Old 09-06-2018, 01:39 PM   #45
68Stepbed
68Stepbed's Avatar
Exactly!!
Matt
Old 09-06-2018, 02:43 PM   #46
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Beautiful country -- there's some like it where I live, and many of the roads are just like in your pic. Edge stripes on two-lanes following the contours of the land. Flatlanders get nervous, say the roads are too dangerous. Horsefeathers, all you gotta do is drive between the lines and you're fine! Just watch out for deer, rocks, tourists, and God forbid, bicyclists on roads like these.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 09-06-2018, 06:24 PM   #47
volksworld
all of the above reasons....plus iirc the discs use larger wheel bearings and spindle diameter...i'm not positive cause i did my conversion 38 years ago and it was necessary then....
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 09-06-2018, 10:07 PM   #48
57taskforce
All about them K’s
57taskforce's Avatar
Reminds me of home in the blue ridge. Thanks to the picture those mountain roads are no joke they get real fun in the snow when you can’t see the lines. Pretty good pucker factor of the back side at times. Disks are king in the mountains no doubt about it.
Tyler
57taskforce is online now   Reply With Quote
Old 09-06-2018, 10:14 PM   #49
toolboxchev
Driving right is cost effective. Both in terms of parts and driving. I have an awesome life insurance policy.
Old 09-06-2018, 10:29 PM   #50
Hotcorner
Hotcorner's Avatar
Originally Posted by toolboxchev View Post
Me I am different, Black Sheep different. I have 4 wheel drums on my rig. Properly maintained they stop on a dime when I want them too.
Do discs work better and are easier to maintain, absolutely! Do I wish to spent the extra money to do this on my rig, Nope, keeping it keeping on they way it was intended to be. 4 wheeled skids and all.
That’s my philosophy on my ‘69 K25. Unless a stellar 71 comes my way.
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
brakes, disc, drum
