09-03-2018, 10:27 PM | #1 |
307 vs 350
I’m rebuilding my gmc 1500. It has a crate 350 with a quad jet in it. I’m picking up another frame to start the rebuild and it has a stock 307 with a 2 jet on it. Which engine setup would give me better gas milage. I’m making the gmc into a 2500 so I can haul heavy loads easier. My shocks are beyond worn out atm. I’ve heard rumors of the fabled extremely efficient 307 but I’m not sure if they are true. And the 307 is all original.
Posted via Mobile Device |
09-03-2018, 11:12 PM | #2 |
Re: 307 vs 350
I replaced my 307 with a crate 350 a few years ago. I didn't notice any significant change in fuel economy, but there was quite a difference in power. I think the 350 has a much easier time moving the truck, which means less throttle is necessary.
09-03-2018, 11:18 PM | #3 |
Re: 307 vs 350
had a 307 in a 73 ,it was gutless
09-04-2018, 11:11 AM | #4 |
Re: 307 vs 350
Of the 2 motors 350 for sure especially for towing
As previously mentioned the less it has to work the better you are Built it for torque not horsepower You won't regret it Have fun |
09-04-2018, 02:10 PM | #5 |
Re: 307 vs 350
Bigger cubic inches is always better.
09-04-2018, 02:24 PM | #6 |
Re: 307 vs 350
What do you want to do with the truck?
The 307 in my wife's '68 Malibu was a very good motor--stock 2bbl would bark the tires upshifting with the Powerglide. And it did get good mileage. The 350 will probably do a better job if you are pulling decent sized trailers or putting heavy loads in the bed. Or if you want to lay rubber, transform tires into smoke, and that sort of thing. But, if you are past those sorts of showy acts and using the truck just as a cruiser/DD or with only light loads or trailers, you may be very happy with the 307. FIRST, evaluate your goal. THEN choose the tool to accomplish it.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
09-04-2018, 02:55 PM | #7 |
Re: 307 vs 350
Your building a 3/4 ton and worrying about mileage
71 C-20 07 Magnum RT AWD |
09-04-2018, 04:18 PM | #8 |
Who Changed This?
Re: 307 vs 350
IK,R?
OP, tell us what trans (stick, auto?) and differential ratio you have. I'd personally recommend the 350 if you are doing any towing. There is no replacement for displacement. I have a 402 in my truck and am looking at putting in a 454.
09-04-2018, 05:47 PM | #9 |
Re: 307 vs 350
Also, the efficiency of a first gen 350 is rather awful. For instance, I had one shoe-horned into an s10 blazer. Even with a properly tuned fitech fuel injection, I was, at most, getting 18 mpg. I was also running a 700r4 and 3:43 gears.
If you want a bit more mpg, run some highway gears, and get a more modern motor like the 5.3 or 6.0 LS based motors. |
09-04-2018, 06:08 PM | #10 |
Re: 307 vs 350
If your worried about mileage buy a Kia , You can't expect a lot from a 50 year old truck with no overdrive ,And by the time you add up all the costs to change anything your better off just dealing with the mileage your already getting .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-04-2018, 06:11 PM | #11 |
Re: 307 vs 350
350 is the way to go,use the 307 for a boat anchor.
09-04-2018, 07:08 PM | #12 |
Who Changed This?
Re: 307 vs 350
That's right- life isn't all about mileage. I have a Kia for knocking around town, but when I need to haul something or tow my travel trailer, that little econobox stays in the driveway.
09-04-2018, 08:31 PM | #13 | ||
"I ain't nobody, dork."
Re: 307 vs 350
I think this is the first time I've read of someone making a C25 out of a C15. Especially when C25's are plentiful and cheap.
Stick with a 350... Gary
09-04-2018, 10:52 PM | #14 |
Re: 307 vs 350
No mention of transmission. Auto or manual? What percentage of empty versus loaded driving? Are the loads heavy but small in size (like gravel) or is it large and have a big aerodynamic penalty? Are you driving in a region with lots of hills? If your in a mostly flat area and and hauling small heavy loads occasionally. Then the 307 would work well with a manual tranny and maybe some sort of gear splitter. Be aware you won't be bombing down the freeway at 75 much with the 307 loaded. The more drag on the truck ( gravity and aerodynamic resistance) the larger the grade you have to negotiate the more you will want the larger motor. Most of the fuel milage gains made in the last 15 years or so have been because of transmission technology that comes in new trucks. Are you willing step up to a late model transmission and a controller. A lot of this decision has to how you want to drive the truck and if you like shifting the gears yourself.
My dad loved his 71 F250 4x4 with a 300 six 4 speed. It towed his fifth wheel trailer and got 19 miles to the gallon (not towing the trailer of course). When the 305 in my Burban went south I replaced it with a 350. The biggest difference at this point is when I have to pull out on a busy road with a 45+ mph from a dead stop. The new 350 makes this much easier. Enjoy the search for your perfect combination!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
09-06-2018, 01:28 AM | #15 |
Re: 307 vs 350
I've owned both, each serves its intended purpose fully, the 307 did every thing the 350 could do, the gas mileage did not matter. if you want better gas mileage then a better rear end gear ratio is what does that.
09-06-2018, 09:36 AM | #16 |
Re: 307 vs 350
My advise , get an l31 350 , very well designed engine , with towing in mind , very efficient and powerful
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
09-06-2018, 07:19 PM | #17 |
FUJIMO
Re: 307 vs 350
If you want to be a little different check what size the journals are on the 307. If it is a large journal put the 307 crank in the 350 block, order a 327 rebuild kit and a good set of heads. 327 would give you a happy medium and if set up right they can give fair milage and run like a scalded dog.
IF IT DON'T GO--CHROME IT!! I dont mind confusion, I create it! |
09-06-2018, 08:36 PM | #18 | |
Re: 307 vs 350
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
09-06-2018, 08:50 PM | #19 |
Re: 307 vs 350
Nothing wrong with a good running 307 but once it's worn out it's not worth rebuilding when you can get a L31-R 350 for around $2000. The L31-R is way better than the 307 or even the older 350.
09-06-2018, 11:00 PM | #20 |
Re: 307 vs 350
Back in the early ‘80s, I ran a 307 in a 2wd drive, 72 blazer. A mechanic buddy of mine gave me a set of double hump 202 heads that gave me all the power I needed. 18-20 mpg, depending on how I drove. Hanging around the shop one weekend with a case of beer, pulls the blazer in and inserts a piece of stainless steel door screen between the four barrel and the intake. Increased the mileage to about 25 and give me a little power. He commenced to tell me that the screen heats up and changes the fuel to a vapor when it hits it. Of course the vapor burns hotter and requires less fuel. Says it was developed back in the late 60’s, but the oil companies bought the patent and locked it away. Of course, I’m just a naive 17 year old kid at the time so I take it all in. All I know is I could burn ‘em at the lights and passed a few more gas stations.
09-07-2018, 09:38 PM | #21 |
Re: 307 vs 350
I have hualed some crazy loads with my 72c10/307 w/ 3.73 gears. It was a good engine. gearing makes all the difference
