Old 09-05-2018, 09:12 AM   #1
KJSR
KJSR's Avatar
Fuel level sender adjustment
I recently installed a new fuel level sender on my 1969 C10. My low level reading seems close but my full is reading 3/4 tank. Is there an adjustment on the sender or is it as simple as bending the float arm to calibrate. I haven't checked the ohms yet either......Thanks for looking!
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
Old 09-05-2018, 07:05 PM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: Fuel level sender adjustment
My new sending unit float arm needed some tweaking to get it to not hang up at the extents of travel and to read the right ohms. Started with the old stock sender to match the appropriate shape and worked from there.
Don't know how much was storage and shipping damage to the shape of the float support wire and how much was manufacture error.
I tied a thin string to the float and ran it out through the filler neck so I could run it through the range of motion with the lock ring secured in place on a new O-ring so everything was in the correct location.
An empty tank will let you hear the float hitting the sides of the tank better too. Mine started out stuck all the way down and only needed a 1/4" adjustment to correct the clearance problem. Not much room for side to side error in our tanks.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-06-2018, 08:30 AM   #3
KJSR
KJSR's Avatar
Thanks for the reply. I never thought it could be hanging up. I will look for that as well.
1936 Chevrolet 1/2t
1964 Chevrolet C10
1969 Chevrolet C10
1937 Plymouth P4
