Gas Cap/Filler Neck
Hello,
The previous owner of my truck filled in the gas cap area...but, not very well. Honestly, I like the look of the gas cap sticking out - as it looks more finished. My question is, where is a good place to get these parts? Do I just need to cut part of the gas tank filler neck off so the cap has something to screw to - or is that sold as an assembly as well that connects to the rest of the filler neck? |
Re: Gas Cap/Filler Neck
My gas cap slides onto an aluminum round neck about 6 inches long which then slides onto a rubber boot that fits over the gas tank neck. It requires 2 large hose clamps. There is a rubber boot or grommet that fits between the tank neck and the body to fill in the space.
![]() ![]() ![]() Join Date: Jan 2018
Hopefully this pic helps
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
![]() Join Date: Jan 2011
So the tank has been moved? When I moved my tank to the back I machined a cap and filler neck look alike out of a piece of 3" aluminum bar stock. Wanted no chance of someone pulling the cap and pumping gas into the cab. Got to love New Jersey the last state in the union where you are not allowed to pump your own gas. Depending on how they filled the hole will determine what it takes to un-fill it. The cab has a rolled lip that the grommet goes into and depending on how the welding was done will make or break getting it removed.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Ok, thanks for the help guys! Jimmy, yes - the tank is moved to the bed - it's just a keg that is used as a gas tank. Kind of cool, but not really my style, so I will be moving it under the bed at some point. I will probably have to get something made since most of my airride stuff keeps me from running a stock under the bed one. Regarding how it was filled in, I looked on the inside of the cab and it appears that the rolled lip is still there. I will snap a pic of that.
