Another BBC oil pressure question
Got my big block running and been having some issues with the oil pressure gauge. I am running an Autometer electric, and I am losing trust in the gauge, Put a second sending unit in, and then the gauge seemed like it was sticking at first. Anyway now it is showing around 20 psi at idle, and about 35 psi at 3000 rpm. Went to 4000 and it didn't go any higher. This is with Valvoline 10W30 oil. Does this seem like a safe amount of oil pressure? I may get a mechanical oil pressure gauge after all of this.
1968 SWB Step Side, Big Block, 4L80E , Running! |
Who Changed This?
![]() Join Date: Jan 2013
Re: Another BBC oil pressure question
How many miles on it? Mine was rebuilt a couple of decades ago (~100k miles on it since then), and pegs the gauge when cold. I don't like that, but it's been that way since the rebuild. It now runs about 30 PSI at hot idle, if the gauge max is 80 PSI. If the gauge max is 60 PSI, then the hot idle is about 25 PSI. 20 PSI isn't that bad, I would think. I run 10-40, though. Truth is, the lighter the oil you run, as long as there is a film present, you should be good to go.
cold pressure or hot.
20 at the low end is a bit low but with 30 wt warmed up it might be normal for an older engine. the high pressure at higher rpm is a bit more concerning. change to a 40 wt and see what happens when its warmed up. next fix would be to put a high volume hi pressure pump in there and see what that does to psi hot at high rpm but watch that cold pressure on start up. may be just tired old truck engine |
I would try a mechanical gauge just to be sure.
Newly rebuilt motor. Hot. I am going to change the oil filter to make sure it is not plugging up with assembly lube first. Then I will try 40W. Already ordered a mechanical gauge.
Be careful of the 40 weight,don't rev when cold,you could blow out the rear seal,other problem would be oil not travelling fast enough on start up and starving rods and cam bearings, 10 w 40 would be better,
O'rielly has a $14 mechanical gauge... shows in stock. I'd hafta know TODAY.
I have 25-30k miles on a .40 over 454 in the Blazer. I run 20/50 and the mechanical gauge shows a tad over 60lb at 2000 rpm cold and a little over 40lb at a 700 rpm idle. It looses about 10lb over all when it warms up. Not sure if my gauge is dead accurate but it's consistent.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
Took off the break in Wix and put on a K&N filter, and now I have 30 psi at idle and about 45 psi at 3500 rpm. Feel a lot better. Not completely warmed up.
GOOD NEWS!!! Did you cut the break-in filter open to see what it had caught?
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! Last edited by RustyBucket; 09-09-2018 at 03:33 PM. |
Don't have a cutter to open it up. If I hack saw it open I don't think I would be able to tell much.
![]() Join Date: Aug 2004
You can cut it with a big set of wire cutters on the flange. That doesn't make too much of a mess.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
