09-09-2018, 11:43 PM | #1 |
71 K10 front drive shaft remove and install help
So I recently got this 1971 K10 from a friend who had it for years but did not really use it much and didn't have much history on it. The front drive shaft is in need of replacing and there are plenty of places to get rebuilt ones with a core swap. It looks like a pretty simple job. I may cuss the 4 bolts on the transfer case side of the shaft as I can't really see them but I can feel them enough to get to them. That part might be a slow process that I won't love but, is it really a simple as I think it may be or is there anything or special tool that may help? It seems like the 4 bolts on the rear of the double cardan and the 4 nuts on the front by the U Joint, then collapse it a little and it should drop right out. Does this sound right or am I missing anything before I get into it?
The pickup has a 350 motor, NP205 transfer case, TH350 trans if I understand everything correctly. Last edited by Chris 71 K10; 09-09-2018 at 11:52 PM. |
09-09-2018, 11:55 PM | #2 |
All about them K’s
Re: 71 K10 front drive shaft remove and install help
Yep just about that easy. Nice looking truck you’ve got there!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
09-10-2018, 07:16 AM | #3 |
Take the differential joint out first and straighten the shaft. The CV joint has fine threads and an angle on the joint is hard on the threads.
PS don't worry if you can't get the bolts completely out because of interference with the transfer case.
09-10-2018, 07:43 AM | #4 |
I put the t case in "N" and unlock one hub and lock the other. I undo the one bolt that has the most clearance. 1/4" 12 point bolt if I remember. It takes a bit of time and I cramp up a bit... HAHA but then I unlock the hub and turn the shaft to reveal another bolt and lock the hub etc. I kick myself sometimes for not installing a later style flange that has nuts and bolts. Mostly because I had one and sold the t case it was on. FACEPALM! My rear flange is from a FURD one ton and has big bolts and a double cardan from Tom Woods. Nice unit.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-10-2018, 10:23 AM | #5 |
I had luck taking the trans cover off and out from interior, made it alot easier to access the rear bolts at the transfer case
09-10-2018, 10:55 AM | #6 |
Thanks guys, always a helpful board with good tips and feedback.
09-10-2018, 10:57 AM | #7 | |
