Old 09-10-2018, 01:23 AM   #1
spspspspoon
Best exhaust manifold? 65 c10
65 c10 short step
3 on tree..3.73 rear
235/55/20 100 spoke knock offs..bout 30" tall
86 c10 front end
80s vette? squareport 350.. 5 way, port n polish, 194 heads thumper cam
Estimated 375-400hp at motor
Current random long tube headers work fine sound fine they dip below my frame rail
(they do keep my starter Hot off highway amongst other short comings)
I'm wanting shorts like block huggers or 2 1/2" ram horns
Cast iron retains heat more than metal of headers
Which is better and either dump straight down or back at an angle?
Going 2 1/2 back to cut outs between bed and cab then 2 1/2" in 3" out xtube or 3" slightly after
Probably boring frame to lay up in it
Curve above axle and dump on the down sweep
Headers cool faster
Without work are ram horns better
What about c4 manifolds?
They seem to be headers already
Had anot her profile but can't sign into it
Thanx
spspspspoon is offline   Reply With Quote
Old 09-10-2018, 01:06 PM   #2
raidmagic
raidmagic's Avatar
Re: Best exhaust manifold? 65 c10
I've got a couple of sets of C4 manifolds. They are all independent tube header like manifolds. They are not even length tubes though. They work great for tight spots. If you're dead set on not having long tubes that's what I would do.
raidmagic is offline   Reply With Quote
Old 09-10-2018, 01:14 PM   #3
andyh1956
I'm running two engines with the Chi-Kneez Vette knock off Ram's Horns. No problems to report. Bought both sets at swap meets for 1/2 price!
andyh1956 is offline   Reply With Quote
Old 09-10-2018, 11:51 PM   #4
Captainfab
60-66 Nut
With a manual trans in a '673-'66 you are pretty much limited to a rams horn style exhaust manifold.
Old 09-16-2018, 09:53 PM   #5
spspspspoon
It seems tight..
350 in 6 cyl position
3 on the tree
Trying to figure also exit down or slanted..
Most stock ones seem unequal lengths to collector
Ram horn style or shorties sa me ability of clearence?
Old 09-16-2018, 09:54 PM   #6
spspspspoon
Being rams are iron or such and headers thinner metal..heat retention? ?
Old 09-17-2018, 12:01 AM   #7
Captainfab
60-66 Nut
In the '63-'66 trucks all engines mount in the same rearward location, whether it is a I6 or a small block. The stock rams horn manifolds dumped straight down. Yes the shorty headers will work as well as long tube headers designed specifically for the '55-'72 trucks. Yes the exhaust manifolds will hold the heat a bit longer than headers.
Originally Posted by spspspspoon View Post
It seems tight..
3 on the tree
