Old 09-12-2018, 09:00 AM   #1
Nodnarb76
Nodnarb76's Avatar
Front wheel bearing question
I am about to replace the front brake rotors on my 87 3/4 ton suburban.
When I get the new rotors, I will need to replace the wheel bearings at the same time. My question is: what all will I need? Looks like I need inner and outer bearings as well as seals. Do I need inner and outer bearings, and inner and outer seals as well?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 09-12-2018, 09:41 AM   #2
rpmerf
rpmerf's Avatar
Re: Front wheel bearing question
It should be:
Outer race
Outer bearing
Inner race
Inner bearing
Inner seal
You may want to pick up a new nut, washer, and dust cap.
Doing a disc brake swap on my 70. Have parts from an 83. Here is what is on my shopping list if the rotors / bearings need to be replaced.
Wheel Seal 3 SKF https://www.rockauto.com/en/moreinfo...032567&jsn=656
IWB + Race 11 SKF https://www.rockauto.com/en/moreinfo...032567&jsn=706
OWB 13 SKF https://www.rockauto.com/en/moreinfo...428&cc=1032567
OWB Race 8 SKF https://www.rockauto.com/en/moreinfo...306&cc=1032567
Spndl Nut 8 Dorman https://www.rockauto.com/en/moreinfo...581&cc=1032567
Dust Cap 4 Dorman https://www.rockauto.com/en/moreinfo...022&cc=1032567
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 09-12-2018, 10:16 AM   #3
Ski-me
Ski-me's Avatar
I'd think that's about it. I assume the new rotors will have the races in there?
Inner, Outer bearings and a seal. New dust cap, cotter pin and nut.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 09-12-2018, 01:21 PM   #4
D13
D13's Avatar
Some rotors do but most do not. CHeck the part description carefully. ANd don't buy cheap bearings if you plan to keep the truck.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 09-12-2018, 06:58 PM   #5
74CustomK20
74CustomK20's Avatar
I buy national bearings n they come with races. My rotors did too but I hit out the new preinstalled ones and just used them to install my national ones. Didn't do that one time n they didn't last 2 weeks.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 09-13-2018, 11:53 AM   #6
CSHADES
CSHADES's Avatar
New rotors come with cheap Chinese races, always replace with quality races and bearings
CSHADES is offline   Reply With Quote
