Old 09-06-2018, 06:07 PM   #1
68panelman
68panelman's Avatar
Aluminum diff covers
Both trucks of mine leak a little from the rear diff covers and I'm wanting to get aftermarket finned aluminum. Sure I can't straighten out the old ones and apply copious amounts of silicone and be done with it, but not worth the effort.
My 70 Blazer is the easy no brainier, large capacity cover, but my 2wd 67 is in question with this type of finned cover, it seems to protrude further out then stock. My question is it seems the track bar would hit. I called suppliers and of course their staff can only read off a computer screen just as I am doing the same, given the same information I've already read, seems to be the norm nowadays?
Any suggestions as to types and brands?
Thanks, Mike
68panelman is offline   Reply With Quote
Old 09-06-2018, 06:19 PM   #2
72LB
72LB's Avatar
Re: Aluminum diff covers
Most all require relocating the trac bar.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 09-07-2018, 07:27 AM   #3
68panelman
68panelman's Avatar
Well ok, that sucks. The squeeze wouldn't be worth the juice to me
Old 09-07-2018, 07:37 AM   #4
I agree. It's a close fit with all original set-up, so nothing deeper will work w/o other alterations
Old 09-07-2018, 07:49 AM   #5
biketopia
The Moser aluminum girdle cover I have on my 71 fit's no problem.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 09-07-2018, 07:55 AM   #6
68panelman
68panelman's Avatar
Can you post pictures when you get a chance?
I contemplated this type since it's flat where the bearing supports are, seemed like the only type that would work.
Old 09-07-2018, 08:04 AM   #7
68panelman
68panelman's Avatar
OK, looking at the Moser on Summit, and read reviews and one guy had a 72 with it installed, the track bar looks to be in stock location?
Old 09-07-2018, 09:55 AM   #8
71cadc10
71cadc10's Avatar
stock track bar with the Moser cover definitely fits, for 12 bolt apps.
aftermarket adjustable track bars, won't fit unless you get the type with the bend in them. I had a stock bar in my '71 with the Moser cover....then when I ordered the porterbuilt adjustable bar, I opted for the one with the 'z' bend in it that is made to clear the aftermarket covers.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 09-07-2018, 10:26 AM   #9
biketopia
That's the exact cover I have, and yea I have stock rear suspension, for the moment. Good point on the aftermarket bars too!! I have my bed off my truck at the moment, I'll snap a picture this afternoon when I get home.
Old 09-07-2018, 10:50 AM   #10
68panelman
68panelman's Avatar
Much appreciated to all the guys, thanks biketopia for the extra info.
Only complaint was some of the bolts were too long and had to be cut, did you also experience this biketopia?
Thanks, Mike
Old 09-07-2018, 02:55 PM   #11
biketopia
I put mine on probably close to ten years ago. I don't remember having to though. I'll dig through some old pic of when I built it and see if I had any mention of it.
Old 09-07-2018, 03:00 PM   #12
68panelman
68panelman's Avatar
Ok, cool
Old 09-07-2018, 09:12 PM   #13
mike16
so why are you replacing the cover? just because it was damaged. frankly I would just put another sheet metal on on there. everything else is expensive and over kill
mike16 is offline   Reply With Quote
Old 09-08-2018, 07:21 AM   #14
72LB
72LB's Avatar
I almost bought the Moser but was told if it's lowered it wouldn't work without relocating the trac bar.
Old 09-08-2018, 09:39 AM   #15
68panelman
68panelman's Avatar
Replacements seem cheap and tinny, so while I'm at it, might as well upgrade. My late model truck has these Mag-hytec units, I like em'
Old 09-13-2018, 01:46 PM   #16
biketopia
Sorry for the long delay, forgot I took the pictures!!
Old 09-13-2018, 02:04 PM   #17
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Mine is lowered 4" in the rear so I did two things to get all kinds of clearance. First, I used a stack of SAE 5/8" washers to move the bar away as much as a full nut would allow, 4 or 5 washers. Secondly, I bent the bar up to clear the thick center portion of the cover. Bending the bar served two purposes on the lowered rear, it centers the rear end as well as clears the girdle cover...I'll dig some pics up...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 09-13-2018, 02:13 PM   #18
biketopia
Old 09-13-2018, 02:40 PM   #19
68panelman
68panelman's Avatar
Attachment 1820459
Attachment 1820460
Thanks for the pics
Looks as if it would hit if compressed more than where it's at now
Old 09-14-2018, 07:38 AM   #20
biketopia
Never had it hit, I used to load it down with a 4 wheeler and coolers and drive it like the 20 year old I was never had it hit.
Old 09-14-2018, 08:39 AM   #21
68panelman
68panelman's Avatar
Great, thanks again for all your help.
Old 09-14-2018, 10:06 AM   #22
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have the same cover on my 12 bolt in my 1972 C15. Lowered 4" in rear and the stock bar fits on mine with no interference as well.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-14-2018, 11:18 AM   #23
68panelman
68panelman's Avatar
Thanks Gary for the extra assurance!
