Old 09-15-2018, 12:55 PM   #1
weider1717
Oem valves or as close as possible needed for 1987 350 heads
Machine shop put in used unmatched set on valves and lost my originals which was fine.
I am wanting to put all new valves as I don't like the mismatched set in them after getting them back. If I cannot get the exact ones that came in it could someone please direct me to the most like for like set. thank you!
weider1717 is offline   Reply With Quote
Old 09-15-2018, 05:01 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: Oem valves or as close as possible needed for 1987 350 heads
This is a very weird request. What exactly is mis-matching about the valves? My bet is they are all oem style valves. All stock replacements are the most like oem you can get. Anything else is a lot more money and a machine shop wouldn't waste those on a person not paying for them.....
Old 09-15-2018, 06:44 PM   #3
weider1717
What I mean is I gave him the heads with gem valves that was not bent. I got back valves from other vehicles that are different shapes and mismatched I do not like this and want a new set.
what do you recommend? what they do is just pull from a bin of used cleaned valves that fit and just pop in a valve not caring it wasn't the valves that came out of my heads.
it was a Napa shop and a half A job if you ask me I wouldn't do that.
Old 09-15-2018, 08:18 PM   #4
Jake Wade
Jake Wade's Avatar
http://www.competitionproducts.com/S.../#.W52gbPZFyM8
This is for 1.94 intake valves. Not sure what size your head takes but, this should help you get an idea of cost.
Jake Wade is offline   Reply With Quote
Old 09-15-2018, 11:53 PM   #5
andyh1956
Besides the face dia you need to know the stem dia of the ex valves. They come 3/8" & 11/32".
andyh1956 is offline   Reply With Quote
Old 09-16-2018, 12:08 AM   #6
Jaysonb
Jaysonb's Avatar
I brought a head into a machine shop a few years ago to get it checked out, I had 1 bad valve, he had a used one on hand, cleaned it up, lapped it to the seat, and it worked great. No reason to change all of them for 1 or 2 mismatched valves. If they are in there, they must be the correct size, what exactly are you worried that is going to happen with the ones that they replaced?
Jaysonb is offline   Reply With Quote
Old 09-17-2018, 08:36 AM   #7
weider1717
These look spot on to my orignials much closer than what he put back in it. Some are 100% flat some have a perfect round circle dish etc but these pictured if they are actually as pictured are very close to was in them originally.
Someone mentioned stem size anyone know for sure which stem size would be in an 87 5.7 350 before I order these?
Old 09-17-2018, 08:14 PM   #8
Jake Wade
Jake Wade's Avatar
Should be 11/32" unless the heads are from a HD2500 or 3500 5.7.
The exhaust valves had 3/8" stems on these.
What is the casting numbers on your heads?
Old 09-18-2018, 09:44 PM   #9
weider1717
Hey, sorry I am just now seeing this. The heads are 14102193 if I got that right. Are you sure the stems not 11/32 on both?
Old 09-19-2018, 08:31 PM   #10
weider1717
original valves looked like the ones in this video. Just a smooth edge into the dished area. I received wrong ones back some exhaust ones perfectly flat etc.
