Old 09-18-2018, 10:28 PM   #1
sodly
sodly's Avatar
C20 rear cab mounts
Hi. Has anyone had Steele Rubber re-vulcanize their C20 rear cab mounts (the "shear" style mounts with the rubber blocks)? Wondering what kind of luck you had. I worry that the re-vulcanized mounts might come back a slightly different height than the originals which would cause the cab to end up either too high or too low relative to the bed. Too low can be shimmed but too high would be a problem. Anyone have any experience with this? Thanks.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 09-18-2018, 10:31 PM   #2
yelmer
Re: C20 rear cab mounts
mine came out great very nice work
yelmer is offline   Reply With Quote
Old 09-18-2018, 10:35 PM   #3
sodly
sodly's Avatar
And the height was correct? All the trim lines up between the cab and bed?
WANTED:
Old 09-18-2018, 10:38 PM   #4
yelmer
i did them on the green truck came out great going to do the red truck next
Old 09-19-2018, 09:36 AM   #5
60-66
60-66's Avatar
Anyone try hot riveting the bracket back to the frame or are you bolting them back on ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
