Old 09-06-2018, 10:33 AM   #1
Hart_Rod
Hart_Rod's Avatar
PBFab driveshaft carrier bearing spacer???
Does anyone make and sell a driveshaft carrier bearing spacer for a PBFab rear setup?
Hart_Rod is offline   Reply With Quote
Old 09-06-2018, 01:39 PM   #2
Willie Makeit
Willie Makeit's Avatar
Re: PBFab driveshaft carrier bearing spacer???
I don't see a reason why this won't work. Carrier bearing dimensions shouldn't be different.
https://www.gsimfab.com/gsi-1-inch-c...4276_8760.html
If this won't work, shoot me a PM with the dimensions you need. I might be able to help.
Willie Makeit is offline   Reply With Quote
Old 09-06-2018, 02:14 PM   #3
Hart_Rod
Hart_Rod's Avatar
Thanks! I think I will need one at least 2-2.5" tall, but will get better measurements after I get the driveshaft back.
Old 09-06-2018, 05:58 PM   #4
SCOTI
SCOTI's Avatar
Why not just use some 2" square tubing?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-09-2018, 03:44 PM   #5
smbrouss70
smbrouss70's Avatar
AZ Pro Performance has one that is either 1.5" or 2.5" tall with shims to raise them another .75"
https://azproperformance.com/product...acer-63-87-c10
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-12-2018, 04:16 PM   #6
enduroride
enduroride's Avatar
Hart Rod, this is what I used, just a 2" solid stock bar from a machinist I know
2016 Silverado2005 GMC Sierra
2002 Chevy Slverado Extra Cab (youngest sons)
2009 GMC Denali (oldest sons)
2015 Lexus 250i (wifes)
1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY"
http://www.louisianaclassictruckclub.com
enduroride is offline   Reply With Quote
Old 09-18-2018, 08:57 PM   #7
NC_John
NC_John's Avatar
I just made my own out of some aluminum stock.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 09-19-2018, 07:42 AM   #8
Hart_Rod
Hart_Rod's Avatar
Thanks guys. I ended up buying a AZPro one from a fellow board member.
